03/ 04 saturn ion remote starter diagram
giggy3
Posted: October 19, 2004 at 9:59 PM / IP Logged
  I need a remote starter wire diagram for a 2003 and 2004 Saturn Ion can any one help me
Dave
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 10:14 PM / IP Logged
Saturn
ION
2003-2004
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   See Note Below*
See Note Below*
Ignition #1:
   Dk. Blue
IGNITION SWITCH HARNESS
Ignition #2:
   N/A
Ignition #3:
   See Note Below*
See Note Below*
Accessory:
   Brown
Brake Light:
   Lt. Blue (+)
Above the brake pedal switch
Tach Signal:
   White (ac)
Ignition Control Module Above Engine
Parking Lights:
   Brown (+)
Found at BCM**
Headlights:
OEM Alarm Disarm:
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * The WHITE/ black wires found on the Key Sense Module. Two relays and resistors will have to be obtained. Please call for more notes and information. ** BCM (Body Control Module) located in the center of the dash, part of the fuse panel.
Saturn
ION
2003-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   Red
Found at the BCM**
Starter Kill:
   See Note Below*
See Note Below*
Ignition +12 Volts:
   Dk. Blue
Dome Lights/Superv:
   See Note Below***
See Note Below***
OEM Horn:
   Black (-)
Found at BCM
Power Lock:
   White (-)
Please see note below****
Power Unlock:
   Single wire (-)
Trunk Release:
Alarm Input Wire:
   See Note Below***
See Note Below***
Notes:
*** The driver door trigger is lt. GREEN/ black. The passenger door is lt. blue, must diode isolate both wires. These wires are located at the BCM (Body control). **** The Lock wire negative trigger. Unlock is negative trigger 1.5K ohm resistor. Lock/unlock wire is found at the BCM (Body Control Module).
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 10:15 PM / IP Logged
ION 2003-2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED ( X2 )
IGNITION HARNESS
IGNITION 1 DK. BLUE IGNITION HARNESS
IGNITION 2 SEE NOTES ( *1 )
IGNITION HARNESS        *SEE DIAGRAM*
ACCESSORY 1 BROWN IGNITION HARNESS
STARTER SEE NOTES ( *1 ) IGNITION HARNESS        *SEE DIAGRAM*
PARKING LIGHTS ( + ) BROWN AT HEADLIGHT SWITCH
DOOR TRIGGER SEE NOTES ( *2 ) SEE NOTES ( *2 )
POWER DOOR LOCK WHITE SEE NOTES ( *3 )
POWER DOOR UNLOCK SAME WIRE SEE NOTES ( *3 ) (TYPE B)
TRUNK RELEASE BLACK/ WHITE     ( + ) AT THE BCM SEE NOTES    ( *4 )
TACH SENSOR WHITE OR ORANGE IGNITION CONTROL MODULE ON TOP LEFT OF THE ENGINE, PIN B OR G
BRAKE
LT. BLUE ( + ) AT THE BRAKE SWITCH
HORN
BLACK ( - ) STEERING COLUMN
FACTORY DISARM
WITH FACTORY REMOTE
FACTORY ANTI-THEFT PASSLOCK 2 SEE NOTES ( *1 ) 791 REQUIRED *SEE DIAGRAM*
     NOTES:
*1 - AT THE IGNITION SWITCH YOU WILL FINE A WHITE WIRE AND A WHITE/ BLACK WIRE. THE WHITE WIRE ACTS AS KEY SENSE, SECOND IGNITION, STARTER AND PASSLOCK. WHEN DOING A REMOTE START WILL NEED TO SEE THE DIAGRAM ON HOW TO A INTERFACE A REMOTE START.
*2 - THE DOOR TRIGGER HAS TWO WIRES, THE DRIVERS DOOR IS LT. GREEN/ BLACK PIN 45 AND THE PASSENGER DOORS ARE LT. BLUE PIN 44. THE BCM PLUG THAT THE DOOR TRIGGERS ARE IN IS C4. MUST DIODE ISOLATE EACH.
*3 - THE DOOR LOCK ARE AT THE BCM, LOCK IS A NEGATIVE TRIGGER AND UNLOCK IS A NEGATIVE THRU A 1.5K OHM RESISTOR. MUST USE RELAYS. PLUG C3 PIN 33
*4 - THE BODY CONTROL MODULE ( BCM ) IS PART OF THE FUSE/ RELAY BOX IN THE LOWER CENTER OF THE DASH, JUST BELOW THE HVAC CONTROL ASSEMBLY. THE BCM HAS FIVE PLUGS, C1 37PIN BLACK PLUG, C2 38PIN GRAY PLUG, C3 56 PIN BLACK PLUG, C4 56PIN GRAY PLUG, C5 6PIN GRAY PLUG.
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 10:17 PM / IP Logged
Make: Saturn
Model: Ion
Year: 2004
Alarm
Constant 12 volts RED UNDER STEERING COLUMN
Ignition 12 volts SMALL BLUE IGNITION SWITCH HARNESS
Starter NO STARTER WIRE SEE TECH #241
Dome Light L GREEN/ BLACK AT DOR PIN SWITCH*
Trunk Pin Switch L GREEN (-) HARNESS PASS SIDE OF CONSOLE.
Parking Lamp BROWN (+) AT SWITCH HARNESS TOP SIDE OF **
Power Lock WHITE (-) GROUND #217
Power Unlock WHITE (-) GROUND WITH 1.5K
* Drivers Door Pin Is L GREEN/ BLACK Ans All Other Doors Are On A L BLUE (-) At Passengers. You Can Also Find Both Of Them In Harness Pass Side Console. ** Steering column. #241-See GM Passlock 2004 Interface Diagram Information Courtesy Of Installer!!Any Additional Information Apreciated!!
View Diagrams
Accessories
Window Up D\ P\ D\ P\
Window Down F/ F/ R/ R/
Ign Key Warn
Trunk Release BLACK/ WHITE (-) @ SWITCH #231
OEM Horn BLACK (-) YELLOW CONN AT TOP OF STEERING COLUMN
Headlights PINK/WHITE (+) HARNESS PASS SIDE OF CONSOLE
OEM Alarm Arm RF ONLY
OEM Alarm Disarm RF ONLY
View Diagrams
Remote Start
Tach Signal WHITE @ IGNITION CONTROL TOP SIDE OF ENGINE.
Ignition #2 #241
Ignition #3
Accessory SM BROWN AI IGNITION HARNESS
Neutral Safety
Brake Light L BLUE (+) HARNESS ON PASS SIDE OF CONSOLE
Reverse Light
Rear Window Defrost
View Diagrams
