e bay cheapo lcd alarm tach wire?
sikassscivic
Member - Posts: 33
Posted: October 23, 2004 at 2:26 PM / IP Logged
i think its a fm 2000 or something close to that.it dosnt have a tach wire listed in the crapy instructions.it just has a strange yellow wire coming from the side that is about 15 foot long.in the crapy directions it says its a 12 volt out put wire,i metered it and i dont get any thing from it.could this be my tach wire??its not in the harness with all the other wires,it comes straight from the case and is yellow and very long.
Teken
Gold - Posts: 1,492
Posted: October 23, 2004 at 2:47 PM / IP Logged
Leave a direct URL link for the product, or confirm the name of the unit.
Getting help starts with you, supplying the proper information.
No information = No answers / Half Aszz Guess's
Regards
EVIL Teken . . .
mo12v
Posted: October 23, 2004 at 3:23 PM / IP Logged
I've been known to :
MO
sikassscivic
Member - Posts: 33
Posted: October 23, 2004 at 4:18 PM / IP Logged
http://cgi.aol.ebay.com/ebaymotors/dll?ViewItem&item=7923655445&category=33721
a link to the auction,its called a 2000 f/s,i have no ideal who actually made it.it doesnt say any where on the box.
Platinum - Posts: 12,488
Posted: October 23, 2004 at 4:32 PM / IP Logged
What are some other wires in the harness ? The YELLOW wire is an output which would not be for the tach signal. You need an INPUT for the tach signal for remote start.
sikassscivic
Member - Posts: 33
Posted: October 23, 2004 at 4:37 PM / IP Logged
the instructions for this thing really suck.all the other wires are basic,just usual stuff,but no tach wire,no ground when armed wire and there is a jumper on the brain,but no where in the directions does it say what that jumper is for??
Scott35
Silver - Posts: 258
Posted: October 23, 2004 at 5:10 PM / IP Logged
That wire is probably just like the Phoenix digital, needs to see +12v before it will crank.
Tacomacrew
sikassscivic
Member - Posts: 33
Posted: October 23, 2004 at 5:25 PM / IP Logged
the car cranks,it just lets the starter go for a few seconds longer than i like,then shuts off after a 20-25 seconds.like its waiting on a tch signal,and because it dosnt see it,it shuts off,the dick i bought it from said he just sells them and has never installed on,yeepee!!
mo12v
Posted: October 23, 2004 at 6:10 PM / IP Logged
Is there a FCC number on the unit?
MO
daniel2002p
Silver - Posts: 524
Posted: October 23, 2004 at 6:21 PM / IP Logged
this is probably one of those units that will stop cranking when the particular wire sees a 12v signal.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
