2001 Jeep Cherokee JP-LK-TB1
jherrick
Member - Posts: 42
Posted: October 25, 2004 at 11:14 AM / IP Logged
Hi.  I have purchased an RS-900 VII and a JP-LK-TB1 to install in a friend's 2001 Jeep Cherokee.  I was wondering if anyone here has any experience with the combination of these two units or with the JP-LK-TB1 in any Jeeps.  If anyone has had any issues before, it would be a great help to know about them before I start this install.  The Jeep does not have the window roll-up feature, so I don't need to worry about that not working correctly.  Thanks in advance.
Jim
jherrick
Member - Posts: 42
Posted: October 25, 2004 at 2:45 PM / IP Logged
Hi.  Another question about these data bus interfaces such as this one and the JDL-PK.  Looking at the wiring diagram for the JDL-PK it looks like the only wire that the remote start connects to the JDL-PK with is the (-) while running.  I hook up the outputs to the JDL-PK (lock/unlock, horn) to the wiring chassis of the jeep?  OR is it that everything except the (+)12V constant and ground get connected to the corresponding wires on the remote start?  Thanks.
jherrick
Member - Posts: 42
Posted: October 26, 2004 at 6:30 AM / IP Logged
Re-reading my post, the question did not seem clear.  So to make the question a little more clear, when I connect the remote starter and the databus module, do the lock/unlock from the remote start go to the vehicle wiring harness or the databus module?
mo12v
Posted: October 26, 2004 at 8:41 AM / IP Logged
If U R using.....JP-LK-TB1 or JDL-PK
Yes .......U would connect your Door Lock / UNLock wires from your RS to your DATABuss Interface & NOT the vehicle Door Locks
combination module that incorporates a doorlock and an alarm databus interface with a transponder bypass
MO
jherrick
Member - Posts: 42
Posted: October 26, 2004 at 8:52 AM / IP Logged
MO, thank you.  That was the question I had.
So the only wires ON THE COMBINATION MODULE that actually get connected to the vehicle wiring harness are the:
Data Output
+12 constant
ground
and the rest get connected to the related REMOTE STARTER wires.  Correct?
mo12v
Posted: October 26, 2004 at 8:56 AM / IP Logged
As long as U have the wiring items from the RS that will work with your vehicle, as described in the DATABuss Interface install manual
MO
jherrick
Member - Posts: 42
Posted: October 26, 2004 at 9:24 AM / IP Logged
I have not actually received the items yet, but have been looking around online for the manuals.  I found the install and users manuals for the RS900VII on the Crimestopper web site, but could not find anything for the JP-LK-TB1 (the item I have ordered).  Also, for the JDL-PK, all I have been able to find is the diagram, no manual.  When the items come I will read the manual, of course, before I start the install, and things should become more clear about what you mean by wiring items.
Thank you.
mo12v
Posted: October 26, 2004 at 3:13 PM / IP Logged
On the JDK-PK...Try from this site:
http://12voltshop.com/download.asp?prodid=JDL-PK
MO
jherrick
Member - Posts: 42
Posted: October 28, 2004 at 10:06 AM / IP Logged
Yes, That is the diagram I was referring to.  Thank you.  You mentioned in a previous post "As long as U have the wiring items from the RS that will work with your vehicle, as described in the DATABuss Interface install manual" and I was wondering what you meant by that.
Jim
hagmanti
Silver - Posts: 304
Posted: October 28, 2004 at 11:37 AM / IP Logged
The RS itself hooks up (via many wires) to your car. That has to be working properly, or else the JDL-PK module is useless.
Me
