DEI Transmitter Range
onstottc
Member - Posts: 9
Posted: October 26, 2004 at 2:51 PM / IP Logged
I've noticed that the range on my Python 881 is not that good. I mounted the antenna above the rear view mirror in my '95 dodge. Any ideas or fixes?
Ravendarat
Platinum - Posts: 2,806
Posted: October 26, 2004 at 2:56 PM / IP Logged
is the antenna in tint? Also is the ground testing at an acceptible resistance. I am not fimiliar with the antenna used on those units but if it is a xhf anttena I would check with the local dealers to be sure that there are no complications with it. I know here as well as in Winnipeg the XHF antennas get sh*t range and we must give the customers an upgrade to the xhf plus antennas
extreme1
Silver - Posts: 1,070
Posted: October 26, 2004 at 3:10 PM / IP Logged
Make sure your antenna is below the tint line, That antenna is the same used on the Valet 554R.
I usually mount them to the left of where the mirror mounts.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
onstottc
Member - Posts: 9
Posted: October 26, 2004 at 6:56 PM / IP Logged
Is there any way to tell the difference between the XHF and XHF plus antennas?
kgerry
Platinum - Posts: 3,455
Posted: October 27, 2004 at 10:30 AM / IP Logged
yes, look at the antenna itself, one says XHF and one says XHF Plus
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
onstottc
Member - Posts: 9
Posted: October 27, 2004 at 5:29 PM / IP Logged
Bizzarre. Mine does not say XHF or XHF plus. Its a black piece of plastic with an antenna coming out of each side and directed's logo.
godsegoizhuge
Copper - Posts: 214
Posted: October 27, 2004 at 10:39 PM / IP Logged
this is the 2 way system right? If it's like my old viper 2 way, i had to replace the alarm brain. You could try moving the antenna to like the side of windshield and have it run along side the plastic window trim.
DaRacerz
Member - Posts: 13
Posted: October 27, 2004 at 11:00 PM / IP Logged
Don't know what you checked, but I had an issue like this as well. 'cept I would be able to rectify it by removing and reconnecting the connector to the antenna. FOund out later on, the cable inside was breaking from a bend and just had to recrimp a new connector and worked great again.
BTW, is the XHF Plus antenna compatible with old brains using the XHF Antenna and is there a big bennefit of range?
