OEM keyless entry Receiver location 98 GM
mastiff
Member - Posts: 6
Posted: November 14, 2004 at 3:21 PM / IP Logged
Would someone please tell me where the OEM keyless entry receiver( BCM?) is located on a 98 GMC truck I think mine has died as the remotes will not unlock/ lock the doors.
This is the last thing I need to check, all the fuses are good and the locks work from the door switches. It just died all the sudden.
Thank you
Mastiff
Take care of business or business will take care of you.
mastiff
Member - Posts: 6
Posted: November 14, 2004 at 3:35 PM / IP Logged
ok dont know why the above happend but please read below
Would someone please tell me where the OEM keyless entry receiver is located on a 98 GMC truck I think mine has died as the remotes will not unlock/ lock the doors.
Thank you
Mastiff
mastiff
Member - Posts: 6
Posted: November 14, 2004 at 3:36 PM / IP Logged
Thank you
Mastiff
mastiff
Member - Posts: 6
Posted: November 14, 2004 at 4:19 PM / IP Logged
ok seeing how i messed up the above post
a 98 gmc reg cab truck, does it have a bcm for OEM keyless or does the keyless have a reciver?
also need the location of this magic black box please.
reason = keyless entry dead but pwr door locks still work at the door switch any help would be greatly appreciated.
mo12v
Posted: November 14, 2004 at 6:25 PM / IP Logged
Power LockL BLUEDRIVER KICK
Power UnlockWHITEPANEL **
** Without OEM Keyless Entry  - Reversal Rest At Ground Door Locks
  With OEM Keyless Entry  - Positive Pulse Door Locks
RKE ModuleBEHIND DRIVER DASH ABOVE AND TO THE RIGHT OF THE STEERING COLUMN.
OEM RelaysBEHIND DRIVER DASH ABOVE BRAKE PEDAL
MO
mastiff
Member - Posts: 6
Posted: November 14, 2004 at 6:58 PM / IP Logged
thank you, just one more question is it common for the RKE Module to go bad?
mo12v
Posted: November 14, 2004 at 10:09 PM / IP Logged
Not sure about common...........Anything is possible.  I would want to check your Remotes first.  Your local Alarm shop should have a frequency / signal checker to see if they are sending signal.  You might even try programming them first.
MO
mastiff
Member - Posts: 6
Posted: November 14, 2004 at 10:33 PM / IP Logged
this is what i have done so far.
1 checked fuses = good
2 used two differnt remotes one was a spare that came with the truck end result = nothing still not working.
i will try the reprogamming thing next
thank you for the help once again.
Jediknight1274
Posted: November 15, 2004 at 8:31 AM / IP Logged
ok this might sound stupid, but make sure the batteries in your transmitter are still good, i've personally never seen one of these mods go bad.  And they are typically DEI made.
SMCinMD
