push button start/stop
j.a.kelly
Member - Posts: 19
Posted: November 24, 2004 at 3:28 PM / IP Logged
I am looking at wiring in a momentary button that will start AND stop my engine? Is this possible and if so how?
I will still be using my key for the ignition.
thanx in advance
JK
Thanx 4 your time
Sandungero24
Member - Posts: 44
Posted: November 24, 2004 at 10:36 PM / IP Logged
push button start/stop -- posted image.
Mwsounds
Copper - Posts: 61
Posted: January 05, 2005 at 9:46 PM / IP Logged
This can also be done if you have a DEI alarm. Just connect the White with blue stripe wire to one side of a momentary switch then  connect the other side to ground.
Thanks,
Mike Ward
Get it done right the first time!
