Valet 554r Question
gatf4
Member - Posts: 20
Posted: November 28, 2004 at 12:55 PM / IP Logged
05 Chevy Equinox with passlock II bypass module.
Everything works perfect except the vehicle won't remote start unless I disarm the system first.
I have the blue wire on the Bypass module and the keysense wire on the BCM both hooked up to the Blue -200 amp output factory disarm wire on the valet system.  I thought that might be the wrong wire or I have to change a setting somehow using the bitwriter.  Thanks in advance.
Scott35
Silver - Posts: 258
Posted: November 28, 2004 at 2:45 PM / IP Logged
I believe if you have the 2 wires hooked to the one you need to diode isolate them. To keep one from backfeeding on the other.
Tacomacrew
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
