2004 ford crown vic police package
Scfd7fd3
Posted: December 04, 2004 at 3:52 PM / IP Logged
i need a wiring diagrahm foe the 2004 ford crown vic door locks. i am trying to in stall a key less entry
mxxmikexx
Silver - Posts: 796
Posted: December 04, 2004 at 5:02 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / CROWN VICTORIA / 2004 / Keyless Entry
[PRINT THIS PAGE]
12volts brown and lt. green   +   ignition harness
Starter RED / lt. blue   +   ignition harness
Ignition WHITE/ yellow   +   ignition harness
Power Lock pink / YELLOW      driver kick, door harness
Notes: Without keyless entry the door locks are 5wi (reverse polarity). With keyless entry they are positive trigger.
Power Unlock pink/lt. green      driver kick, door harness
Lock Motor pink/black   5wi driver kick, door harness
Unlock Motor RED / orange   5wi driver door motor in door
Parking Lights+ brown   +   pin 4, blk plug @ LCM
Notes: The LCM (Lighting Control Module) is to the right of the steering column.
Parking Lights- WHITE/ black   -   pin 13, gry 16P plug @ LCM
Hazards same as turn signals
Turn Signal(L) lt. GREEN/ orange   +   steering column
Turn Signal(R) ORANGE / lt. blue   +   steering column
Door Trigger dk. blue and BLACK/ orange   -   LCM
Notes: Blue is the driver door trigger wire, it is in pin 11, gray 22 pin plug. BLACK/ orange is the three passenger doors, it is in pin 11, gray 16 pin plug. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Release purple / YELLOW   5wi driver kick, harness to rear
Notes: The fuel door release is WHITE/ pink (+) in the driver kick, harness to rear.
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Horn Trigger dk. blue   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: SecuriLock Part #: 556U or 555U
Notes: N/A
Sunday, December 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
