Remote start no start
jspbtown
Member - Posts: 27
Posted: December 08, 2004 at 6:51 PM / IP Logged
Installed an Omega RS-7K2 on a 2001 Grand Voyager last year. It has worked fine until now. Now, it will flash just once, and not make any attempt to start the car. Even if I put the key in the ignition, and turn it to the "on" postion, it will not start. It is not making the 3 attempts that it should. One quick flash and then nothing. I have checked, and it is not in the valet mode.
I tried the re-programming steps thinking the remote is not in sync, but the unit does acknowledge the remote. Ideas?
swamprat323
Gold - Posts: 1,335
Posted: December 08, 2004 at 7:11 PM / IP Logged
Do you have a shutdown diagnostiocs, if so, what does it say. Does the RS try to start but the started never engages.
Or Rs wont activate at all.
jspbtown
Member - Posts: 27
Posted: December 09, 2004 at 7:54 AM / IP Logged
Nothing in the manual about any "shutdown diagnosis". No, the unit does not make any attempt to start the car. usually it will make 3 tries to start the car, but now it does one brief flash of the lights and thats it. On another car I installed one on, when I had a problem with the alarm bypass it would come on, light all the lights in the dash, and attempt three times without starting. On this car, all I get is one quick flash. And again, it has functioned flawlessly for 1 year and no changes to the car.
hagmanti
Silver - Posts: 304
Posted: December 09, 2004 at 9:22 AM / IP Logged
Is the hood pin grounding out?
Is there a switch connection that's not connected (either to ground-- possibly called neutral safety).
Are the brake lights on?
Is this installed in a car w/ a manual transmission? If so, might be a problem w/ door pin...
Me
jspbtown
Member - Posts: 27
Posted: December 09, 2004 at 9:57 AM / IP Logged
You know I checked the hood pin to see if it was moving freely, but I didn't check to see if it was grounding out. Possibly a piece of the insulating plastic broke off? I will check that. Brake lights are not on (assuming you are referring to a bad brake light switch right?). Nope, it is installed in a Chrysler mini-van. Automatic transmission. I'll check the pin but any other suggestions in the mean time are welcome!
hagmanti
Silver - Posts: 304
Posted: December 09, 2004 at 10:17 AM / IP Logged
Not only could the pin itself be bad, but the wire could be too tight around a piece of metal (for instance, where it goes through the firewall) and become stripped...
Me
swamprat323
Gold - Posts: 1,335
Posted: December 09, 2004 at 11:37 AM / IP Logged
Use a DMM and check all voltages at the IGN wires from the RS unit and at the starter output.
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
