trunk release for jetta 1995
stereotornado
Member - Posts: 10
Posted: December 11, 2004 at 7:27 PM / IP Logged
l'm installing a viper 350 on a jetta 1995 and l want to install the trunk release, can somebody tell me the wiring diagram for it and the relay diagram if l needed. thanks.
furredoutgixxer
Member - Posts: 35
Posted: December 11, 2004 at 8:47 PM / IP Logged
its a grey wire at the back of the switch. you must isolate the switch from the release wire. to wire it you cut the wire, run the wire form the switch side to 87a of a relay. the other side of the wire goes to 30 connect 87 and 86 to 12 volt and 85 to the trunk release wire.
stereotornado
Member - Posts: 10
Posted: December 12, 2004 at 7:16 PM / IP Logged
thank you for help me
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
