Remote Start on Man Trans
Mazdawg
Member - Posts: 6
Posted: October 16, 2002 at 12:13 AM / IP Logged
Does anyone know of a safety switch or similar device to disable remote starting if trans is left in gear?
thanx myke
Montrealler
Copper - Posts: 155
Posted: October 16, 2002 at 3:39 AM / IP Logged
Better to use a car starter design for this kind of application. A logical sequence protect the ingear start and avoid you the pain to install switches on shifter.
If you see an advice on car starter telling you that you should not install into convertible car , you may prevent the reach of the shifter with a microwawe alarm sensor but it's your own risk !!!
Yes I'm Back 2006...
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
