Clifford Intelliguard 700 IQ Troubleshoot
bigpappy
Posted: December 15, 2004 at 8:03 PM / IP Logged
My car alarm appears to have died when the battery was disconnected by a mechanic. It survived 2 disconnects in the past 3 weeks (spark plug change and new battery). This was just to install the battery shield the idiot left sitting on top the engine when they changed the battery. Alarm is non-responsive to valet switch and remote.
Alarm installer is no longer in the business and dealership couldn't locate anybody who knew this alarm. They tried calling Clifford w/o luck and from prior experience I don't expect much from clifford.
Any troubleshooting hints or places for the mechanic to contact?
hagmanti
Silver - Posts: 304
Posted: December 16, 2004 at 11:28 AM / IP Logged
Disconnect the alarm-- if there are harness going into the main brain, disconnect them for several minutes (even an hour), and then reconnect them up. (Make sure you know where your valet key is-- this is likely to trip the alarm).
If that doesn't fix the problem, your brain may have finally given up the ghost, and it may be time for a brand-spanking new alarm...
Me
auex
Platinum - Posts: 5,041
Posted: December 16, 2004 at 12:15 PM / IP Logged
Check the fuses for the alarm, reconnecting the battery could have potentionaly blown the fuse.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
