Window roll up Infiniti G35
srusin1
Copper - Posts: 86
Posted: December 19, 2004 at 4:09 PM / IP Logged
What do i need to do a window roll up on this car? It has the auto window up and down on the switch on the door panel. Im installing a Viper 791xv?
profuse007
Gold - Posts: 2,015
Posted: December 19, 2004 at 5:50 PM / IP Logged
Extended triggers on the power door lock wires will roll the windows up and down.
use any status wire from 791xv
Houston,TX
srusin1
Copper - Posts: 86
Posted: December 19, 2004 at 5:52 PM / IP Logged
SO no additional modules are needed? So which aux outputs would I use? Any what keys are to be pressed to do the roll up/down.
profuse007
Gold - Posts: 2,015
Posted: December 19, 2004 at 5:55 PM / IP Logged
no, besure to diode isolate it from the lock wire.
actually, you can hold down the lock button to extend the pulse.... i think. try this first, if not use the status wire.
Houston,TX
wblakes
Copper - Posts: 202
Posted: December 19, 2004 at 9:18 PM / IP Logged
sorry for being stupid, but how do you use the status output wire to roll the windows? the way i did it before was use an aux output to the roll the windows.
