’00 Chrysler 300M alarm/remote start
antol11
Member - Posts: 6
Posted: December 20, 2004 at 8:23 PM / IP Logged
Hi,
I am currently installing an alarm/rs in a 2000 Chrysler 300M.  Everything is going smoothly for the most part but I don't know how/where I can route wires through the firewall?  If anyone has experience with the 300M and would like to enlighten me with the best (or in other words easiest) location where I could route wires throught the firewall I would greatly appreciate it.  Please don't tell me that  I am going to have to remove the seating and pull pack the carpeting and drill.
Thanks in advance,
Bogdan
extreme1
Silver - Posts: 1,070
Posted: December 20, 2004 at 8:52 PM / IP Logged
through the grommet for the shifter cable, it's above the gas pedal.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Ravendarat
Platinum - Posts: 2,806
Posted: December 21, 2004 at 1:44 AM / IP Logged
You can also go through the gromet that the hood release cable travels through.
antol11
Member - Posts: 6
Posted: December 21, 2004 at 9:47 AM / IP Logged
Thanks guys,
I'll look at both locations and go with what works for me.
Thanks again,
Bogdan
antol11
Member - Posts: 6
Posted: December 22, 2004 at 2:20 PM / IP Logged
Just wanted to say thanks again,  it was as easy as pie once I knew where to look!
Bogdan
antol11
Member - Posts: 6
Posted: December 22, 2004 at 2:25 PM / IP Logged
Hi,
The wiring info for the 2000 Chrysler 300M says the tach wire is at the "coil" and is tan/white.  My problem is I don't know where the "coil" is.   Also when they say coil do they mean distributor?
I found a tan/white wire in one of the looms but it reads .7VAC and doesn't fluctuate when I hit the gas.
Can anyone describe the location of the tach wire with more detail?
Thanks,
Bogdan
extreme1
Posted: December 22, 2004 at 5:00 PM / IP Logged
tan white at PCM behind drivers headlight
Shaughn Murley
Visions Electronics
Red Deer, Alberta
