98 Bravada remote starter
mevenson
Posted: December 21, 2004 at 7:23 PM / IP Logged
I bought a Crimestopper 900VI remote starter, I then bought a DEI 555 L for the Passlock 2 system bypass. I have tried several times to get it hooked uo correctly but it hasn't started yet. It will crank for a few moments but never starts. The owners manuals for both pieces I bought call wires different things. I think I am not bypassing the Passlock 2, or I am not hooking up the OEM arm and OEM disarm wires up correctly. I was wondering if anyone had a wire diagram for the Bravada or any ideas of what wires I am hooking up wrong . I do have a good ground. Thanks in advance for any help or  pointers you can give.
mevenson
daniel2002p
Silver - Posts: 524
Posted: December 21, 2004 at 11:28 PM / IP Logged
Oldsmobile
Bravada
1997-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
PINK
Ignition #2:
WHITE
Ignition  #3:
N/A
Accessory:
ORANGE
Brake  Light:
WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT PCM MODULE
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
YELLOW (+)
AT HEADLIGHT SWITCH
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped With PASSLOCK II Anti-theft system. See Note # 113 - Bypassing PASSLOCK II Theft Deterrent System Diagram.
Oldsmobile
Bravada
1997-1999
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
OEM Alarm Disarm:
LT. GREEN (-)
DRIVER'S KICK PANEL
Dome  Lights/Superv:
WHITE (-)
AT PIN SWITCH OR COURTESY LIGHT
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
LT. BLUE (+)
DRIVER'S KICK PANEL **
Power  Unlock:
WHITE (+)
Trunk  Release:
BLACK/ WHITE (+)
AT RELEASE SWITCH
Alarm  Input Wire:
WHITE (-)
Notes:
* See Installation Note #202 - Positive Pulse Door Lock Diagram.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
eurotek
Copper - Posts: 58
Posted: December 21, 2004 at 11:34 PM / IP Logged
make it simple, i bypass the passlock II with a resistance that is easily measured.. works everytime,
place the resistance from the cut yellow wire that leads away from the key, and connect it to the other, black or orange w/black wire..
u might have a good connection, but unless the output from the crimestopper for bypassing is timed just right, it might not activate the 555L
