Installation of Remote Starter on 1999 Ch
Mark_o
Posted: December 29, 2004 at 3:29 PM / IP Logged
Hi,
I just got this 1999 Chrysler Cirrus very low mileage and want to install a Prostart 3 in 1 Remote Starter, Power door/trunk lock and Security system in it.
My main concern is how to attach the wires from the wire harness supplied with the system to the wires in the car. ( The instructions recommend soldering them) ** Can someone please describe the exact process?
Now when I installed a Cruse Control in my 94 Sundance (I pulled from the wreckers) it was easy, I just had to change a couple of sensors and plug it in. With this unit they have a warning on the installation instructions that only a qualified technician should attempt install the unit.
My plan is to get the Chilton manual and use the installation instructions with it, But any additional information would help.
Thanks,
Mark
Your Friend in Auto Repairs
KarTuneMan
Platinum - Posts: 7,056
Posted: December 29, 2004 at 3:43 PM / IP Logged
12volts red, pink/black   +  ignition harness
Notes: When doing remote start red should not be used for main power. Use pink/black.
Starter yellow   +  ignition harness
Second Starter
Ignition dark blue   +  ignition harness
Second Ignition GREEN/ red   +  ignition harness
Third Ignition
Accessory blk/orn & blk/wht   +  ignition harness
Second Accessory
Keysense
Power Lock WHITE/ green   +  rear of fuse box under dash
Notes: Use positive (+) trigger thru a 620 ohm resistor to lock, and a positive (+) trigger thru a 2.7K ohm resistor to unlock. Must use relays.
Power Unlock same wire
Lock Motor ORANGE / black   +  drivers kick panel
Unlock Motor blue/white   +  drivers kick panel
Parking Lights+ BLACK / YELLOW    dr kick or behind fuse box
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow   -  front of fusebox
Notes: In a three pin connector near the door jam.
Dome Supervision
Trunk/Hatch Pin tan/black   -  driver kick panel
Hood Pin
Trunk/Hatch Release BLACK/ white   +  driver kick panel
Power Sliding Door
Factory Alarm Arm GREEN/ orange   +  kick or BCM
Notes: Lt. GREEN/ orange from drivers door or dk. GREEN/ orange from passenger or catch either at BCM located behind right side dash. Use a positive (+) trigger thru a 940 ohm resistor to arm, and a positive (+) trigger thru a 470 ohm resistor to disarm. Must use relays.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer BLACK/ gray    coil pack
Notes: If BLACK/ gray on V6 causes starter to drag, use any one of the fuel injection wires at injectors at front of engine. The injector wire will be the one that IS NOT dk. GREEN/ orange.
Wait to start
Brake Wire WHITE/ tan   +  at brake switch
Parking Brake
Horn Trigger BLACK/ red   -  steering column
Memory Seat 1
snguyen
Silver - Posts: 281
Posted: December 29, 2004 at 4:34 PM / IP Logged
forbidden
Platinum - Posts: 5,354
Posted: December 29, 2004 at 6:39 PM / IP Logged
Take your time if you are going to try this yourself. Yes the lines must be soldered to ensure a good contact. These lines pass a large amount of current through them. If they are not soldered then over time the connection loosens and makes a very unreliable connection that will leave you beating on the poor car.
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
