92 Park ave factory alarm disable
lieast
Member - Posts: 6
Posted: December 31, 2004 at 10:46 AM / IP Logged
Hello, I have a 92 park ave with a remote starter installed. I have permanently wired  a resistor to disable the VATS and the system starts fine except when I lock the car doors via elect locks or factory keyless entry. The factory alarm enables thus not alowing me to remote start plus the horn honks and the lights flash.  manually locking the doors is a pain. I have been leaving my car unlocked for the time being. Is there a way to disable the factory alarm when i initiate a remote start? Any help would be great. Thanks,
Mike
KarTuneMan
Platinum - Posts: 7,056
Posted: December 31, 2004 at 10:58 AM / IP Logged
There should be a Lt.green wire in the drivers kick, its a Neg(-) trigger. Should disarm you factory security
Trigger this wire BEFORE you remote start
lieast
Member - Posts: 6
Posted: January 01, 2005 at 9:48 AM / IP Logged
Thanks,
I will check it out. There sure is a million wires in that kick panel! and a pain to reach too!. Thanks for the input.
Mike
