fiesta si immobiliser
mistert
Posted: January 01, 2005 at 8:20 AM / IP Logged
i have replaced a ford 1600 zetec engine in a ford fiesta with a 1600 dohc from an escort. to begin it went ok until full operating temp was reached then it cut out. there seems to be no spark but engine will turn over and there is power to the coil. is it possible there is an immobiliser causing the problem and how do i bypass it ?
mister t
draasch
Gold - Posts: 2,172
Posted: January 01, 2005 at 10:51 PM / IP Logged
i dont think so......it should keep the car from running at all or just for few seconds....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Scott35
Silver - Posts: 258
Posted: January 02, 2005 at 10:20 AM / IP Logged
Swapping out the coil or the ignition module might fix your problems.
Tacomacrew
