Audiovox programming channel 4,5,6,7
adunph
Posted: January 01, 2005 at 9:52 PM / IP Logged
I just installed an Audiovox APS996A remote starter/alarm in my Accord.  the unit is great, but I cant find in the manual how to program/access the 4 extra channels offered by my remote.  I wanted to program the channel 4, 5, 6, 7 for various things such as Rear Defrost, Front defrost, etc.  I have no problems wiring the system for this stuff, but I just dont really know how to access these features via my remote LCD keychain nor how to program which combinations of buttons will activate the additional channels.  The books shows a few pre-defined ones like "lock+key" will show the temperature inside the vehicle, and "lock+option+key" will enalbe 24 hr daily start program.  Any help would be appreciated.
Audiovox programming channel 4,5,6,7 -- posted image.
Thanks - A.
biker8018
Copper - Posts: 46
Posted: January 02, 2005 at 8:57 AM / IP Logged
to program the extra outputs into the remote you will use a combination of 2 buttons. To begin programming press the program switch 3 times with the key on.Siren will chirp once,press lock button. Press the switch again siren will chirp press unlock. Press the switch again the siren will chirp press the start button. press the switch again the siren will chirp press button 4. Press the switch again the siren will chirp press a combination of 2 buttons for channel 5. Repeat this process for channel 6 and 7. Shut the car off you are done
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
