2001 grand caravan
daveandcc
Posted: January 02, 2005 at 8:49 PM / IP Logged
im putting in a remote starter looking for wiring diagran and how to bypass factory pass key sh*t can anyone help dash i apart and waiting lol  2001 dodge grand caravan with pass key thanks in advance
Craig3708
Copper - Posts: 155
Posted: January 02, 2005 at 9:00 PM / IP Logged
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW (NOTES BELOW
IGNITION SWITCH HARNESS**
Ignition  #1:
PINK/WHITE
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
N/A
Brake  Light:
WHITE/ TAN
Tach  Signal:
PURPLE / ORANGE (AC)
GRAY CONNECTOR BY IGNITION MODULE
Parking Lights:
WHITE/ BROWN (-)
AT HEADLIGHT SWITCH***
Headlights:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 * Many Of These Vehicles Are Equipped With A Transponder (Even If The Key Is Black). Use Universal Alarm Bypass Module Part Numner 2x402 Where X Can Be Any Number. ** NOTE!!! A Second Start Wire (PURPLE / Brown) Needs a relay installed to provide a ground (-) through a 180 Ohm Resistor during crank in order to remote start the vehicle, See Installation Note #162. ***The parking lights are negative trigger through a 2.1K ohm resistor. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness'. This wire will be used to control the bypass module, if needed.
Dodge
Caravan
2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
IGNITION SWITCH HARNESS (MAX #AMPS)
OEM Alarm Disarm:
VIOLET/LT. BLUE
AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE******
Dome  Lights/Superv:
BLACK/ WHITE (-)
AT 4 PIN PLUG NEAR FUSE PANEL
OEM Horn:
GREEN/ PURPLE (-)
STEERING COLUMN HARNESS
Power  Lock:
PURPLE / GREEN
AT PLUG AT PCM ON FIREWALL *****
Power  Unlock:
Single wire system
Trunk  Release:
VIOLET/TAN
AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE ******
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
*****for the 2001-02 Caravan Lock is negative trigger through a 5.3k ohm resistor. Unlock is negative trigger through a 2.0k ohm resistor. For the 2003 Caravan Lock is negative trigger through a 2.2k ohm resistor. Unlock is negative trigger through a 390 ohm resistor. The Body Control Module (BCM) is in the driver kick panel near the the parking brake, ******See Installation Note #211. A Single Pulse Of Ground Through A 2.2 K-Ohm Resistor Will Open The Liftgate. POWER SLIDING DOORS: Violet/Dk. Blue Wire At Switch. Driver's Side - A Single Pulse Of Ground Through A 2.7 K-Ohm Resistor. Passenger's Side - A Single Pulse Of Ground Through A 1.5 K-Ohm Resistor. ****** To disarm the OEM alarm a negative trigger through a 9.20k ohm resistor.
http://www.designtech-intl.com/Content/techsupport/documents/section04/note144.pdf This is a link to making your own bypass module, but I would recommend buying one if you have never made one before.
     Craig...
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
