Boa remote start keyless entry
shaftmaster
Member - Posts: 12
Posted: January 05, 2005 at 9:09 PM / IP Logged
I'm trying to install the the Boa (Model 265B) remote start/keyless entry in my 95 mazda protege' LX. I am having a lot of trouble with hooking up to the power door locks, I think they are a negetive multipex and maybe need a resistor, but I just cant understand the little manual. Boa said they had more info online but I cant log in because my "crash code" has "expired". I just need some guidence for which wires to cut, what resistors i need and where to get them.
Thank you for your time,
Robert
shaftmaster
Member - Posts: 12
Posted: January 05, 2005 at 9:11 PM / IP Logged
If you need more info just ask
thank you
swamprat323
Gold - Posts: 1,335
Posted: January 05, 2005 at 9:19 PM / IP Logged
|       POWER LOCK|GREEN / WHITE        |- |passenger kick panel        |
|     POWER UNLOCK|GREEN/ red           |- |passenger kick panel        |
From Alarm
GREEN/ black go to lock wire in car GREEN / WHITE
purple and PURPLE / black go to ground, you dotn need the fuses you can cut them out.
blue/black go to unlock wire in car GREEN/ red
The WHITE/ black and BROWN / black are not used.
shaftmaster
Member - Posts: 12
Posted: January 07, 2005 at 3:24 PM / IP Logged
  It doesn't have an alarm so  "From Alarm" are you talking about the control modual.
just making sure. thanks for the help
shaftmaster
Member - Posts: 12
Posted: January 07, 2005 at 3:25 PM / IP Logged
and do I need any resistors
swamprat323
Gold - Posts: 1,335
Posted: January 07, 2005 at 6:29 PM / IP Logged
The Brain, keyless unit, no you dotn need resistors.
