Rain Sensor for alarm
Rizzysi
Member - Posts: 13
Posted: January 07, 2005 at 10:40 PM / IP Logged
Wanted to know if anybody knew of any kind of rain sensor that I could use to hook up to my alarm so that when it starts raining it will roll up my windows.  I have a Viper 791XV with both the 530t and 529t window modules.  I've been searching online for a week and can't find anything.  Any help with this would be greatly appreciated.
italnpimp59
Silver - Posts: 427
Posted: January 08, 2005 at 12:22 AM / IP Logged
never heard of such a thing but then again do you think its even possible?  theres no way it could detect the humidity before its already started raining so your vehicle would get a lil wet inside before the windows roll up.  i suggest hook your rollup module to the ground when armed output, that way when you set the alarm....up go the windows
Mobilesecurity
Member - Posts: 28
Posted: January 08, 2005 at 12:34 AM / IP Logged
I PREFER TO HOOK UP WINDOW ROLL UP MODULES TO A SEPERATE AUXILLARY CHANNEL BECAUSE WHAT IF IT'S A WARM DAY AND YOU DON'T WANT THE WINDOWS ROLLED UP OR YOU ARE COMIN RIGHT BACK BUT DONT WANT THEM UP. IF U HOOK THEM UP TO A SEPERATE CHANNEL YOU CAN THE OPTION OF ROLLING THEM UP WHEN YOU WANT TO
check twice connect once
Mobilesecurity
Member - Posts: 28
Posted: January 08, 2005 at 12:36 AM / IP Logged
sorry for the all capsRain Sensor for alarm -- posted image.
Rizzysi
Member - Posts: 13
Posted: January 08, 2005 at 6:47 AM / IP Logged
On most, if not all Viper alarm installs, the window modules are connected to the "ground when armed" wire.  In turn, the alarm will roll up the windows every time I arm the car.  But also, I have the door windows set to channel two and the sunroof set to channel 4.  I can roll the windows up or down independently.  If I don't want the windows to roll up when I arm the car, all I have to do is hit the channel two button before I arm the car, that then sends a signal to the roll up modules to not roll up when the car is armed.
And about the rain sensor.  There is a company out there that makes a rain sensor to be used for your wipers.  It will automatically turn on your wipers when it starts to rain and even adjust the speed of the wipers depending on how hard it is raining.   It uses a sensor mounted just behind the rear view mirror and uses infrared beams to detect rain on the windshield.  I'm not sure if I could use that same sensor and hook it up to a relay for the windows because I believe that rain sensor hooks into a controller that has a microprocessor in it.  Plus, that system is $150!  I really don't want to spend that kind of money.  I was hoping someone out there knew of another idea.  I thought about creating my own, but would first like to see if there's already one out there.
jrilla
Gold - Posts: 1,498
Posted: January 08, 2005 at 10:30 AM / IP Logged
You must be really bored.
J Rilla
Owner/Installer
intuitionx2
Member - Posts: 8
Posted: January 08, 2005 at 5:05 PM / IP Logged
You might be able to use this.
http://www.firstdetection.com/waterbug/200/index.html
The model WB-200 operates on 12 or 24 Volt AC/DC and has a form C relay output that can be connected to alarm panels, bells, dialers, etc
swamprat323
Gold - Posts: 1,335
Posted: January 08, 2005 at 6:44 PM / IP Logged
They have somthing, noit sure if it was ment to be used in cars or not, but saw it on mtv's pimp my ride, and this was for a sunroof.
auex
Platinum - Posts: 5,041
Posted: January 08, 2005 at 11:56 PM / IP Logged
Yeah, unfortanely my gf made me watch that damn show again and I saw the same thing. Don't remember what the brand was though.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Rizzysi
Member - Posts: 13
Posted: January 09, 2005 at 1:03 AM / IP Logged
Ya, I saw it on Pimp My Ride too.  I might just call West Coast Customs out in LA to see what they use...haha
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
