1999 Isuzu Vehicross R/S w/factory alarm
nazrat
Posted: January 11, 2005 at 9:30 PM / IP Logged
I purchased a Persuit/Prestige remote starter for a 1999 Vehicross. The factory service manual doesn't have information on the factory alarm wiring. The wiring info on this site only lists a factory disarm wire. Does the DEI or another wiring database list a factory arm wire?
the12volt.com Alarm link: https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Isuzu&model=Vehicross&ID=18102&type=Alarm
Thanks,
Tad
KarTuneMan
Platinum - Posts: 7,056
KarTuneMan
Posted: January 12, 2005 at 3:11 AM / IP Logged
nazrat
Posted: January 12, 2005 at 6:25 AM / IP Logged
KarTuneMan wrote:
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=2883&product=Remote%20Start
Im guessing it arms with lock!
Thank you. I'll try that again, but in my initial test it didn't arm with lock. Apparently the Vehicross uses an alarm unlike other Isuzus, it's an alarm that Toyota used. It has a high-pitched chirp for lock/unlock and uses the horn for the alarm alert.
Thanks again,
Tad
mobileworks
Copper - Posts: 136
Posted: January 12, 2005 at 7:09 AM / IP Logged
Mayby you have to pulse the door trigger at the same time.
Does it say how to arm the system in the owners manual?  Usually it will tell you ...."using the key fob..."  "....or by opening the door and hitting the lock button on the door panel...."
which is the case in most GM vehicles...
nazrat
Posted: January 12, 2005 at 8:06 AM / IP Logged
The alarm manual is online:
http://www.tonemonday.com/storage/vehicross_alarm_manual.pdf
It lists the only two ways to arm the system are via the key fob, or with passive arming.
I'm thinking that it might be easier to ebay this unit and buy an alarm/rs combo unit rather than working with the factory alarm.
-Tad
KarTuneMan
Posted: January 12, 2005 at 11:51 AM / IP Logged
The astrochart shows the arm wire as RED / white NEG(-) in drivers door
Disarm Lt,GREEN/ red NEG(-) in drivers door
nazrat
Posted: January 12, 2005 at 12:58 PM / IP Logged
Wonderful, thank you!
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
