99 expedition door locks?
1badcad
Posted: January 16, 2005 at 10:26 PM / IP Logged
i installed a basic alarm on my 99 expedition with factory keyless entry. my problem is that when i lock or unlock the doors  they do it like three times. its like if you hold the unlock and lock switch on the car. it's seem like the pulse is to long but the alarm is on the lowest setting alreay. whats wrong is their a way to fix this. i connected the wires to the door locks at the keyless entry module.(the pink ones) also i am having the same problem about the door trigger like everyone esle. if i use the orange and lt. green wire at the dome switch would this solve it i read this on one of the topics. like i said i have a basic alarm no lcd screen or remote start. please help!!!!!!!!!!!!!!
misterjimbo
Silver - Posts: 535
Posted: January 17, 2005 at 8:06 AM / IP Logged
what kind of alarm did you use?
Platinum - Posts: 12,488
Posted: January 17, 2005 at 9:48 AM / IP Logged
How did you connect to the wires ? Did you use sodler and tape or did you use connectors ? Make sure that you have a solid connection and also make sure that you have the connector on the alarm CPU pushed in all the way as well otherwise you get this problem.
What is the problem your having with the door trigger ? Are you getting false alarms ? If so you need to relay & diode isolate the trigger's from each other to fix this problem.
1badcad
Posted: January 17, 2005 at 7:06 PM / IP Logged
i used connectors and yes they are connected right and also the connector on the alarm. i a crimestopper cs2001fc alarm. so what could it be?
mo12v
Posted: January 17, 2005 at 8:20 PM / IP Logged
Doesn't your Crimestopper have Double Pulse Door Lock Programming?  Make sure that it is set to single.  Double check your Lock/ Unlock wiring and put a meter on it to check for pulsing.  Also check your Ground wire.
You may have to put Relays on for a Stronger Ground Pulse.
Power LockPINK / YELLOWPASSENGER KICK
Power UnlockPINK/L GREENPANEL (- ) PULSE
Dome LightBLACK/ L BLUE (+)16 PIN CONN. IN PASS. KICK PANEL
MO
misterjimbo
Silver - Posts: 535
Posted: January 17, 2005 at 8:44 PM / IP Logged
i would suggest leaving the dbl pulde unlock on, unless you used the bcm wake up wire. you used connectors? for door trigger, maybe you should try the light blue white at the keyless module, it is a negative trigger. as far as your issue with the locks, are you sure that you plugged the grey connector all the way into the module? what do the locks do when you press the switch on the door?
sambo0711
Member - Posts: 7
Posted: January 18, 2005 at 8:45 AM / IP Logged
are these five wire locks?
misterjimbo
Silver - Posts: 535
Posted: January 18, 2005 at 8:50 AM / IP Logged
No they are not five wire, as long as u got them at the keyless module
forbidden
Platinum - Posts: 5,354
Posted: January 18, 2005 at 1:32 PM / IP Logged
The keyless module should be high on the drivers side firewall, closer to the side of the vehicle. Look for a white module with two grey molex's
sambo0711
Member - Posts: 7
Posted: January 18, 2005 at 3:15 PM / IP Logged
Hey can someone tell me what they think the BCM wake up wire is, oh and on fords its not a BCM, in this case its called a FEM (front eletronic Module).  I think that just the pule from the alarm to the fem will wake it up, much like the pulse from you unlock button in the car wakes it up.
Wednesday, February 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
