555h bypass
minhbach
Copper - Posts: 93
Posted: January 17, 2005 at 12:56 AM / IP Logged
I have a hard time to program the this 555h transponder for the honda accord 2001 LX, i  sucessfully programed the learn code. But about three hours later the memory lost and now i cannot program the learning code again. Help me please? I cannot program the transponder, when i turn the key on the LED keep on solid but the manual said if if was learned and code and remember, i light should stay off after remote start with the key in the ignition.
profuse007
Gold - Posts: 2,015
Posted: January 17, 2005 at 3:24 AM / IP Logged
you might want to switch the bypass on ahead of time b4 even RS the unit to learn it. some alarm unit will trigger in a delay.
Houston,TX
minhbach
Copper - Posts: 93
Posted: January 17, 2005 at 11:08 AM / IP Logged
Profuse007, can you tell me more specific, thanks
profuse007
Gold - Posts: 2,015
Posted: January 17, 2005 at 12:49 PM / IP Logged
the status input wire, that receive ground when RS. what you can do w/ that is to get another wire and jump from the status input to ground ahead of time b4 even RS to learn the key. that will activate the 555h and learn the key.
Houston,TX
extreme1
Silver - Posts: 1,070
Posted: January 18, 2005 at 1:54 AM / IP Logged
here's the best way to program the 555h.
insert key in ignition.
ground blue wire.
turn ignition key on.
when LED on 555h turns off module is programmed.
if LED does not turn off try another one of the customers keys.
I've gone through both keys only to find the valet is the only one that will program.
Hate those modules.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
minhbach
Copper - Posts: 93
Posted: February 01, 2005 at 12:09 AM / IP Logged
Hey Extreme, I have try want you show me. I put the key in, they the blue wire and turn key to the on position the led did goes off, i don't know if it is program or not. But after that i hook the blue wire to the starter wire on the alarm system, and try to start without the key in the ignition it is still not working. It keeps asking for the key. Are you always run into problems like this.
minhbach
Copper - Posts: 93
snguyen
Silver - Posts: 281
Posted: February 01, 2005 at 12:03 PM / IP Logged
Trying using the PKH2.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
