Command Start Remote Starter
blaker2005
Posted: January 23, 2005 at 1:20 PM / IP Logged
Hello
I have a Command Start Remote Starter that does not work anymore.  I can not find the model # on the unit except Command Start 1997.   It is Grey in color.  Does anyone know if other Command Start models can be simply plugged into my vehicle so that I do not have to rewire it?
For example can a Command Start CS260m be plugged into my existing harness.  This unit looks exactly like mine except it is black.  Any help would be appreciated.
extreme1
Silver - Posts: 1,070
Posted: January 23, 2005 at 2:48 PM / IP Logged
CS260m is for manual transmissions only
Shaughn Murley
Visions Electronics
Red Deer, Alberta
blaker2005
Posted: January 24, 2005 at 4:47 PM / IP Logged
What about a Command Start 290i which was made in 1998?
Can this one be used in place of my unit?
Also, I live in St. John's Canada not Chile.
velcro
Member - Posts: 19
Posted: January 29, 2005 at 1:22 PM / IP Logged
what is your vehicle?  do u have a pic of the remote starter brains and remote?
gus1
Gold - Posts: 1,013
Posted: January 29, 2005 at 4:52 PM / IP Logged
Ahhhh... the venerable CS250. Providing the antenna has the 3 pin plug on it, then yes, the 290 will plug right in. If it's the RCA plug atyle of antenna, then you will require a different antenna for the 290ic.
Gus
