Clifford G5 siren and tilt sensor?
bigwise1
Member - Posts: 39
Posted: January 31, 2005 at 1:37 AM / IP Logged
I have a G5 intelliguard 850 and read somewhere that the clifford g5 sirens were g5 specific. Is this true? I can't just drop a dei 513T piezo and 515R battery backup siren in? A tilt sensor was also installed but it's not very sensitive. Where and what should I look for and is adjustment easy?
its_radio_shop
Copper - Posts: 76
Posted: February 03, 2005 at 9:03 AM / IP Logged
You can put one of those sirens in it if you use the secondary horn / siren output, but on the main siren speaker output, you need to use the clifford speaker. As far as the tilt sensor goes, clifford had one of the best sensors out there and its probably working normally. If your trying to test the sensor by rocking the vehicle it wont do anything, and it isnt supposed to. Arm the alarm and wait for a minute or two, then take a jack and begin jacking you car up like your going to try to remove a wheel. On my 300M the tire doesnt leave the ground before the alarm is tripped. If its not working like that, amke sure the tilt sensor is mounted correctly (as horizontal as possible)
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
