door lock unlock question
muaiad97
Copper - Posts: 207
Posted: February 06, 2005 at 6:15 PM / IP Logged
hi all
guys  i have question .      it happens to me  every time i install  r\s or keyless entry  i take time or hours to find the wires for door luck unlock  my question is  . is ther any easy way to find these wire .so i dont have to go under the dash and look for thes wires . can i  get thes wire from the fuses panal or frome  door swich at the driver door  is ther any different  between thes and to go under the dash  look for wires.  just question...........
 thanx  for any answers
thepencil
Gold - Posts: 1,526
Posted: February 06, 2005 at 7:18 PM / IP Logged
This all depends on the type of vehicle, but to know where the lock and unlock wires are at you have to get a good source of wiring info. diagram.    12 volt has one of these.
or you can to pay for something like this.
wiring info.
Be careful whose advice you buy, but be patient with those who supply it.door lock unlock  question -- posted image.
xtreme069
Copper - Posts: 67
Posted: February 07, 2005 at 5:12 AM / IP Logged
when you lock and unlock the doors with the master lock or switch you more often than not can hear a relay click when you round about find where this click is coming from put your hand on the relays in the area so you can feel the relay click then probe tghe wires in that relay, if there is a master switch then you can sometimes find the wires behind the switch and if the switch is in the door, probe the wires in the kick panel that come through the door jam also some people will find the locking relays in the bcm by probing the circuit board not really recomended but can cut down time good luck and may the force be with you !!! hope this helps
I Love This Industry!!
