Remote Start/Parking Light Question...
Mike_89gts
Member - Posts: 42
Posted: February 07, 2005 at 4:52 AM / IP Logged
ok - my remote start has 2 wires that supply output to my parking lights. On one harness it supplies a +12V output and another harness is supplies a negative 500ma output.
Are these 2 wires getting connected to the same parking light wire
in the vehicle? The one that reads 12v w/ lights on?
Thanks in advance!
Mike_89GTS
Platinum - Posts: 12,488
Posted: February 07, 2005 at 6:45 AM / IP Logged
You use only one of the two. Some vehicles have a (-) wire that triggers the relay while other vehicles have a (+) parking light wire . Use which ever one you want or your vehicle requires. I usually look at which one is easier to get to. If it's easier to use the (-) the I tape up the (+) wire off the alarm harness or vise versa.
dare_ds69
Silver - Posts: 419
Posted: February 07, 2005 at 6:46 AM / IP Logged
what kind of alarm , car, year ?
how own your mind, control your life.
MECP certified. always use a DMM
Mike_89gts
Member - Posts: 42
Posted: February 07, 2005 at 7:19 AM / IP Logged
Thanks for the reply guys!...
It's a crappy tire unit and my car's a 1989 Toyota Celica GTS.
Here's the RS unit I have and the wires in question.
I already have the +12v wire attached to the green +12V
parking lights wire - the wire in question is the one on
the 2 pin harness with the horn output wire.
Remote Start/Parking Light Question... -- posted image.
Appreciate it!
Mike_89GTS
BTW, Jeff @ Velocity Motors - Did you ever use those logos I did for
you sometime ago?
Posted: February 07, 2005 at 7:26 AM / IP Logged
Mike, the YELLOW (-) wire you will not need to use if you already used the YELLOW (+) wire from the other harness. The GREEN wire for the 5th relay to power the 2nd IGN wire ( BLACK/ ORANGE ) at the ignition harness. I ended up using a different logo. The member's liked the current one that we have now, but thanks for the efforts and time.
Mike_89gts
Member - Posts: 42
Posted: February 07, 2005 at 7:39 AM / IP Logged
Thanks a bunch Jeff.
Yeah - the 5th relay thing was figured
to show what 2 parking light wires I
was talking about. - Thanks though.
And, not a problem about the logo.
I owed you one!
Have a good day folks.
Mike_89GTS
Posted: February 07, 2005 at 1:18 PM / IP Logged
No problemo... anytime.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
