1995 Toyota Camry Power Door Lock
td0205
Posted: February 15, 2005 at 3:52 AM / IP Logged
My car is 4 door 1995 Camry. Power door lock in my driver door does not work when I press on the switch on door trim.
As I recall, there are 2 bundles of wires going to power door lock actuator. One bundle has 4 wires and the other bundle has 3 wires. Which wire should I check the voltage at for unlock and lock? What voltages activate the Lock and unlock? Do you have wiring chart or know where I can get more information on this?
Also, there are linkage rods from actuator to outside door handle and to inside manual switch. Do I have to remove outside door handle first before I can remove actuator? In addition, the openning is so small that there is not enough room to remove the actuator. Do I have to remove the glass window assembly as well before I can remove the door lock actuator?
Thank you all for any replies.
auex
Platinum - Posts: 5,041
Posted: February 16, 2005 at 8:49 PM / IP Logged
Ok just to be sure, only the driver's door doesn't work with the switch? If that is the case then I would just add an aftermarket actuator and cut the wires going to the factory one and wire it to the aftermarket. Don't bother to remove the factory actuator.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
