2001 Silverado DEI Passlock help
Accord_boy619
Member - Posts: 16
Posted: February 27, 2005 at 9:17 PM / IP Logged
Im installin a DEI remote start with the 555L paslock module. My problem is that when the truck is started by remote, it starts and dies. any ideas? I hooked up the Yellow to passlock wire ign. side(yellow), Black w / YELLOW to passlock BCM side (yellow), Black to orange w/ black. any suggestions pls.
audioCHIEF
Posted: February 27, 2005 at 9:33 PM / IP Logged
If that is not working U can measure the resistance across the yellow wire  & add a relay and the right resistance.
Chief did it !
Sexified
Copper - Posts: 87
Posted: February 27, 2005 at 9:41 PM / IP Logged
make sure you have the correct yellow wire, there are 2 of them in that harness....3 if you include the starter wire, chances are you either have the wrong wire, haven't powered up the 2nd ignition or the ground while running is not working on the output of the remote starter.
sweet.
Accord_boy619
Member - Posts: 16
Posted: February 27, 2005 at 10:35 PM / IP Logged
I have the right yellow wire cuz when I cut it the truck wouldn't run w/key. But if its hooked up it runsw/key. I have the second ing powered up.
chris354
Silver - Posts: 253
Posted: February 27, 2005 at 10:58 PM / IP Logged
I would try grounding the 555l black wire to the kick panel instead of the ORANGE / black, sometimes the ref. ground is not strong enough for the  555l .
chris354
Silver - Posts: 253
Posted: February 27, 2005 at 11:04 PM / IP Logged
Also are are you using tach or voltage. If the security light is not on when it dies its probally your tach signal.
secureauto
Copper - Posts: 197
Posted: February 27, 2005 at 11:07 PM / IP Logged
Just wondering, did you program the 555L, start the car with the key for at least 5 seconds?
ASE Certified
Accord_boy619
Member - Posts: 16
Posted: February 27, 2005 at 11:31 PM / IP Logged
Yes I programed it
secureauto
Copper - Posts: 197
Posted: February 27, 2005 at 11:37 PM / IP Logged
You can try replacing the 555L or do what audioChief wrote, I've added a link for a diagram:
Passlock bypass using relays
ASE Certified
iskidoo
Silver - Posts: 1,047
Posted: February 28, 2005 at 12:09 AM / IP Logged
You hooked your Red to constant +12v Red in the main harness, Pink to the Pink Ignition in the main harness, and Blue/Black to the status (-) ground out when running from the remote starter correct?
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
