2005 Ford Freestar alarm/remote start wiring
ksingh
Copper - Posts: 62
Posted: March 03, 2005 at 6:15 PM / IP Logged
hey whats up i was wondering if anyone did any install's on this vehicle and can send me the vehicle tech sheet and also can let  me be aware of any problems or tips they have encountered
Kenny
boomer_106
Silver - Posts: 710
Posted: March 03, 2005 at 7:53 PM / IP Logged
I havent done an install on it but, I can send you the tech sheet so here it is.
Ford
Freestar
2004-2005
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
DK. GREEN
IGNITION SWITCH HARNESS*
Ignition  #1:
WHITE/ YELLOW
Ignition #2:
BLACK/ LT. GREEN
Ignition  #3:
N/A
Accessory:
PURPLE / ORANGE
Brake  Light:
RED / LT. GREEN (+)
BLACK PLUG AT THE SJB**
Tach  Signal:
N/A
Parking Lights:
N/A
Headlights:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *This vehicle is equipped with a Transponder Anti-Theft Security System. Use Universal Alarm Bypass Module part #2x402 where X can be any number. ** The SJB (Smart Junction Box)is found under the driver dash part of the fuse box.
Ford
Freestar
2004-2005
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
IGNITION HARNESS
OEM Alarm Disarm:
LT. BLUE/BLACK
Dome  Lights/Superv:
ORANGE / WHITE (-)
BLUE PLUG AT THE SJB**
OEM Horn:
DK. BLUE (-)
Power  Lock:
WHITE/ PURPLE (-)
Power  Unlock:
DK. BLUE/LT. GREEN (-)
Trunk  Release:
YELLOW (-)
GRAY PLUG AT THE SJB**
Alarm  Input Wire:
ORANGE / WHITE (-)
Notes:
dare_ds69
Silver - Posts: 419
Posted: March 03, 2005 at 7:54 PM / IP Logged
hopes it helps
12volts red (20A), lt. GREEN/ pur (20A) +  ignition harness
Starter dk. green  +  ignition harness
Second Starter N/A
Ignition WHITE/ yellow  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory PURPLE / orange  +  ignition harness
Second Accessory BLACK/ lt. green  +  ignition harness
Keysense lt. GREEN/ purple  -  ignition harness
Power Lock WHITE/ purple  -  SJB, black 26 pin plug, pin 3
Notes: The SJB (Smart Junction Box) is part of the fuse box under the driver side dash. The black 36 pin, and the blue 52 pin plugs are on the front. All the other plugs are on the back.
Power Unlock dk. blue/lt. green  -  SJB, black 26 pin plug, pin 1
Lock Motor RED / orange  5wi SJB, black 5 pin plug, pin 3
Unlock Motor yellow  5wi SJB, black 5 pin plug, pin 1
Parking Lights+ each controlled separately
Parking Lights- see DirectFax document 1072
Hazards WHITE/ red  -  SJB, blue 52 pin plug, pin 24
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Reverse Light WHITE/ yellow  +  SJB, gray 52 pin plug, pin 13
Door Trigger use dome supervision wire
Dome Supervision ORANGE / white  -  SJB, gray 26 pin plug, pin 21
Trunk/Hatch Pin use dome supervision wire
Hood Pin PURPLE / orange    SJB, black 52 pin plug, pin 15
Notes: The hood pin wire rests at ground and goes to open circuit with the hood open.
Trunk/Hatch Release yellow  -  SJB, gray 26 pin plug, pin 15
Power Sliding Door wht/lt grn (L), lt grn/red (R) -  SJB, gray 26 pin plug, pins 16, 14
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. blue/black  -  SJB, black 26 pin plug, pin 9
Disarm No Unlock see factory alarm disarm
Tachometer NOT red  ac  ignition coil or any fuel injector
Wait to start N/A
Brake Wire RED / lt. green  +  SJB, black 36 pin plug, pin 5
Parking Brake RED / yellow  -  SJB, black 52 pin plug, pin 50
Horn Trigger dk. blue  -  SJB, blue 52 pin plug, pin 39
Memory Seat 1 BROWN / lt. green  -  SJB, black 52 pin plug, pin 9
Memory Seat 2 BLACK/ orange  -  SJB, black 52 pin plug, pin 8
Memory Seat 3 N/A  -
2005 Ford Freestar alarm/remote start wiring -- posted image.
Immobilizer Bypass Module:Required: YesType: SecuriLockPart #: 556S, 556U, or 555U
Notes: Standard on all models
how own your mind, control your life.
MECP certified. always use a DMM
