Can the 451M control two 5 wire actuators
yahooyahoo
Member - Posts: 13
Posted: March 08, 2005 at 10:51 PM / IP Logged
I'm having problems figuring out how if it can.  I am able to hookup the 451M with a two wire configuration and that works fine but when I go for 5 wire it doesn't work...Can anyone help?
daniel2002p
Silver - Posts: 524
Posted: March 09, 2005 at 8:15 AM / IP Logged
how did you hook it up?
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
yahooyahoo
Member - Posts: 13
Posted: March 09, 2005 at 11:30 AM / IP Logged
Well I was able to make it work as a two wire.  small ribbon cable obviously went to the alarm, purple wire went to +12V, blue and green went to lock and unlock (maybe not that order), white and brown went to ground.  This worked as a two wire.  I thought for the remaining three wires on the actuators I could hook the black to ground and then take the remaining two wires and hook them up to the white and brown on the DEI 451m instead of grounding those two.  I am an amateur though and that isn't working for me.  Any ideas?
yahooyahoo
Member - Posts: 13
Posted: March 10, 2005 at 8:27 AM / IP Logged
Here is the wiring of the five wire actuator:
red - motor (+ve when opening)
Black - Ground (common)
Blue - motor (+ve when closing)
brown - opening trigger (-ve)
purple - closing trigger (-ve)
yahooyahoo
Member - Posts: 13
Posted: March 10, 2005 at 10:00 PM / IP Logged
Can anyone help me?
yahooyahoo
Member - Posts: 13
Posted: March 11, 2005 at 10:07 PM / IP Logged
Nobody?
yahooyahoo
Member - Posts: 13
Posted: March 14, 2005 at 5:51 PM / IP Logged
I guess I'll just go ahead and set them up as two wire if nobody can help me.  Thanks!
