1996 mercedes benz C220 alarm
nava94
Silver - Posts: 296
Posted: March 16, 2005 at 12:52 AM / IP Logged
Hey guyz does anyone have the alarm shematics for this car.
Bmnicolosi
Copper - Posts: 173
Posted: March 16, 2005 at 10:31 AM / IP Logged
12volts red   +  ignition harness
Notes: Ignition harness accessible at bottom of fusebox. Pull fusebox up into cowling area to get at wires. Use PURPLE / green to bypass factory starter kill for remote start.
Starter purple   +  ignition harness
Second Starter
Ignition pink/red   +  ignition harness
Second Ignition pink/grn (2nd acc.)   +  ignition harness
Third Ignition
Accessory pink / YELLOW   +  ignition harness
Second Accessory
Keysense
Power Lock black   -  either kick
Notes: Operates with normal one second ground pulse. These wires also trigger a factory starter kill on the base model cars w/o alarm system. Ignition controlled locking will cause a no-start problem because of this. The PURPLE / brown wire at the door lock pump located in right rear corner of trunk must be grounded for vehicle to start. There is also a single WHITE/ green wire at the dash mounted door lock switch that does not engage the starter kill. No information available at this time about interface with WHITE/ green wire.
Power Unlock blue   -  either kick
Lock Motor
Unlock Motor
Parking Lights+ gray, gray/white    switch or below f-box
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger brn/gry, brn/gry/yel   -  pins or fact. sec.
Notes: Brn/gry at pass. front pin catches both front doors. Brn/gry/yel picks up rear doors.
Dome Supervision
Trunk/Hatch Pin BROWN / yellow/purple    at switch or light
Hood Pin BROWN / red   -  switch or fact. sec.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm same as locks    factory alarm
Notes: Factory security module in trunk (if vehicle has one). May isolate arm/disarm from locks by using relay. Windows also controlled by locking and unlocking doors with key (convenience module also in trunk). Locate wires at each door harness or at module. Colors are green - black at each front door and at motors in rear door, grn/pur and blk/pur at rear doors, and RR window is grn/pur/blk and blk/pur/wht at module. Could not verify circuit type (A,B).
Factory Alarm Disarm same as locks
Disarm No Unlock
Tachometer GREEN/ YELLOW   AC conn. left of brake ped
If you say "I already know how", don't ask me a single question.
