Door switch wiring 2005 camry
Seamus1967
Posted: March 17, 2005 at 6:43 PM / IP Logged
    Ok i found the wires for the passenger and driver doors here is the question I have one postive and negative wire from the alarm module . Would I be able to use a chassis ground for the negative and the two single wires on the door switchs which I believe are positive and splice them together with the one positive wire from the mudule. Seeing how both are switchs and there grounded to the chassis .. I dont know you tell me am I wrong .
thepencil
Gold - Posts: 1,526
Posted: March 17, 2005 at 7:23 PM / IP Logged
You will only need to use either postive or the negative wire from the alarm module, but don't use both. Below is the wiring diagram for your car.
You can get the trigger here:
Dome Supervision, GREEN/ red - negative polarity at the ignition key cylinder light
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / CAMRY / 2005 / Remote Start
12volts WHITE/ red (30A), white (5A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter BLACK / YELLOW   +   ignition harness
Ignition BLACK/ red   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory N/A
Keysense blue   -   ign harn or BECU, top plug, pin 19
Notes: Using the status output to trigger this wire during remote start will disarm the alarm without unlocking the doors.
The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge.
Power Lock blue / YELLOW   -   DKP or bottom of fusebox, 20 pin plg
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock blue (double pulse)   -   DKP or BECU, top plug, pin 22
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is blue/white (-) in the BECU, top plug, pin 21.
Lock Motor blue/red   5wi DKP or bottom of fusebox, 13 pin plg
Unlock Motor blue/black   5wi DKP or BECU, bottom plug, pin 11
Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge.
Parking Lights+ green   +   DKP or bottom of fusebox, 20 pin plg
Parking Lights- red   -   switch or BECU, top plug, pin 8
Hazards lt. GREEN/ black   -   switch or BECU, middle plug, pin 10
Turn Signal(L) GREEN / WHITE   +   turn signal flasher relay in DKP
Turn Signal(R) GREEN/ YELLOW   +   turn signal flasher relay in DKP
Reverse Light RED / black   +   DKP or bottom of fusebox, 20 pin plg
Door Trigger see notes   -   see notes
Notes: The LF door is RED / green in the BECU, bottom plug, pin 1. The RF door is RED / green in the BECU, top plug, pin 11. The rear doors are RED / white in the bottom of the fuse box, 20 pin plug, pin 7. Use all three wires and diode isolate each.
Dome Supervision GREEN/ red   -   ignition key cylinder light
Trunk/Hatch Pin green   -   DKP or BECU, bottom plug, pin 6
Hood Pin black   -   theft deterrent ECU behind glovebox
Trunk/Hatch Release WHITE/ blue   5wi DKP or BECU, bottom plug, pin 12
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer BLACK/ orange   ac   ECM behind glovebox
Notes: On the 4 cylinder models, it is in the 2nd plug from the top, pin 1. On the 6 cylinder models, it is in the top plug, pin 5.
Can also go to any ignition coil or fuel injector and use the wire that is NOT BLACK/ red, WHITE/ red, or WHITE/ black.
Wait to start N/A
Brake Wire GREEN / WHITE   +   sw or bottom of fusebox, 20 pin plug
Parking Brake RED / white   -   parking brake switch
Horn Trigger GREEN/ black   -   sw or bottom of fusebox, 24 pin plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: Standard on the LE V6, SE V6, and XLE models.
Be careful whose advice you buy, but be patient with those who supply it.Door switch wiring 2005 camry -- posted image.
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
