bypassing the passlock
lilchepe
Member - Posts: 43
Posted: April 02, 2005 at 9:39 AM / IP Logged
hey guys whats up , well my question is how can i bypass the factory anti theft system.  i am using a  457g from DEI.  the real problem im having is finding out were the passlock module is located.  can anyone please help me out.
Another way of doing it is using two relays but only problem is it requires a resistor and well honestly i dont know what the resistance measure is.  i apreciate your help thank you .   Sin. Jose
lilchepe
Member - Posts: 43
Posted: April 02, 2005 at 9:47 AM / IP Logged
im sorry guys i forgot to mention this is on a chevy 2005 colorado
NowYaKnow
Gold - Posts: 1,217
Posted: April 02, 2005 at 9:55 AM / IP Logged
I don't think the 457G is applicable on the colorado you would need a 555L or a PLXR.
Mike
Platinum - Posts: 12,488
The Passlock system you will need to use the PLXR from bypasskit and it will also double as your 2nd IGN activation wire. You can access the Passlock wires when you remove the lower portion of the driver's dash. The wire are running along side with the ignition wires .The wires are WHITE/ YELLOW ( POWER ) & WHITE/ BLACK ( DATA ).
lilchepe
Member - Posts: 43
Posted: April 02, 2005 at 10:09 AM / IP Logged
thanks for the advice guys , but is it possible to use a set of relays and if so can i have a diagram please. thanks for the advice once again.  this is the hardest truck i've worked on so guys i apreciate the advice. thanks Sin. Jose
Posted: April 02, 2005 at 11:06 AM / IP Logged
I've tried using the relay diagram before and it doesn't work ( that or I didn't get the right diagram for the Pursuit that I did ). You will need 3 relays and resistors for the set up. It's easier to buy the module and more reliable as well.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
