amplify ground using relay
tarasdad
Member - Posts: 19
Posted: April 02, 2005 at 3:31 PM / IP Logged
i know it is a simple question, and i have looked in the basics column, but can anyone tell me how to use a relay to amplify the ground signal coming out of a keyless entry. is it the same as a regular negative relay?
KarTuneMan
Platinum - Posts: 7,056
Posted: April 02, 2005 at 4:46 PM / IP Logged
Yup....12 volts to pin 86  your neg trigger to pin 85  GROUND to pin 87
pin 30 is your "amplified" ground
tarasdad
Member - Posts: 19
Posted: April 02, 2005 at 6:05 PM / IP Logged
thanks, kartuneman.
