door lock actuators
dj styles
Member - Posts: 14
Posted: November 11, 2002 at 9:55 PM / IP Logged
first i would like to thank everyone for all the helpful info you guys provide. my question is this, i installed some after market actuators on my wifes car on the front doors only, now i want to do the rear doors, will i have to use another set of relays or can i just tap on the ones im using now. the door locks are controlled with the alarm.
gabriel correa
Player69
Silver - Posts: 504
Posted: November 11, 2002 at 9:59 PM / IP Logged
It should have built in relays and you should be able to just tap into the existing wiring.
Ohmz
Copper - Posts: 193
Posted: November 12, 2002 at 4:46 AM / IP Logged
You can tap into the existing relays with no problems. The relays give out enough output to power up all the actuators when connected the right way.
My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
