remote start, non fuel injected
dlatting
Posted: May 05, 2005 at 11:17 PM / IP Logged
can a remote start work if the car is not fuel injected
jb
topless98gt
Member - Posts: 27
Posted: May 06, 2005 at 12:12 AM / IP Logged
Yes, it can, but it is not recommended since carburated cars sometimes have to be pumped before ignition. The worse that could happen is you'll drain some juice out of your battery for a few moments, and then the starter will come back failed if you have a 2-way. Someone please correct me if I am wrong.
kgerry
Platinum - Posts: 3,455
Posted: May 06, 2005 at 1:39 PM / IP Logged
IF THE CAR WILL START WITHOUT BEING PUMPED, SURE... MOST CARBURATED VEHICLES WILL NOT.... even many early throttle body vehicles were iffy at cold, cold temps.... they used to make solenoid kits to use on these (carb) vehicles but they didnt work all that well and you were constantly adjusting them.....
i just tell customers now, if it's not EFI, it's not worth the effort.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
