nuetral saftey switch, 88 Monte Carlo
Atl_monte
Copper - Posts: 90
Posted: May 11, 2005 at 10:38 PM / IP Logged
how or where should I say do I connect the nuetral saftey switch wire of a Viper 791XV on a 88 Monte Carlo it says something about the key buzzer in the instructions but my key buzzer doesn't work...
misterjimbo
Silver - Posts: 535
Posted: May 12, 2005 at 7:14 AM / IP Logged
th key buzzer is  called the key sense wire. not sure on color, but you shuld be at the main ignition harness
mo12v
Posted: May 12, 2005 at 7:59 AM / IP Logged
 Some Models Carburated, Some Throttle Body Injection
Neutral SafetyORANGE / BLACKSWITCH ON STEERING COLUMN
Ign Key WarnLIGHT GREEN(-) STEERING COLUMN HARNESS
MO
Atl_monte
Copper - Posts: 90
Posted: May 12, 2005 at 11:06 PM / IP Logged
which one is the best to connect to? like I said I don'tthink my key warn works?
misterjimbo
Silver - Posts: 535
Posted: May 12, 2005 at 11:25 PM / IP Logged
Well it might just be the actual buzzer that is bad, you can use your meter to see if the wire shows ground when the key is in the cylinder. Either wire will work... Or you could just ground it {did I just say that out loud}
CutDog504
Silver - Posts: 643
Posted: May 13, 2005 at 11:10 AM / IP Logged
On this car you can just ground it. This car has a mechanical neutral safety switch which will physically not let the ign switch turn to crank unless the shifter is in park or neutral. And you shouldnt worry too mush about accentdally starting it in gear. The only way that can happen is if you deliberately turn on the key so you can take it out of park, and THEN press the remote start. So as long as you dont have kids in you car playing with your keys, you you pretty much be alright to just ground the neutral input wire.
Atl_monte
Copper - Posts: 90
Posted: May 13, 2005 at 6:49 PM / IP Logged
I do have an automatic transmission, but everyone is assuming that it is a column shift car, its a SS so its a console shifter but the original shifter was replaced with a B&M shifter which has the little micro switch for the neutral saftety switch...
Atl_monte
Copper - Posts: 90
Posted: May 13, 2005 at 6:51 PM / IP Logged
does the ORANGE / black wire show (-) when ready to start?
mo12v
Posted: May 13, 2005 at 10:06 PM / IP Logged
<<<the original shifter was replaced with a B&M shifter which has the little micro switch for the neutral saftety switch...>>>
U got me there????>>>
The reference I posted was for Factory NSS.......
If U have a B&M, with a different type NSS, then get the Meter out and check........
Should have Negative when in Park...........
Not sure how your B&M NSS shows
MO
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
