horn output
rock1
Copper - Posts: 120
Posted: May 12, 2005 at 11:25 PM / IP Logged
Im using the bulldog 62I and I have a negative horn output
Do I need a relay for this ? 92 mazda 929
desh187
Copper - Posts: 310
Posted: May 13, 2005 at 12:02 AM / IP Logged
If it is negative output,just find GREEN/ red(-) wire in steering column harness which is horn wire on 92-929 and try it.If horn does not honk,then use a relay for stronger ground pulse.
rock1
Copper - Posts: 120
Posted: May 13, 2005 at 1:03 AM / IP Logged
The wire in the car is negative and the wire on the alarm is a negative.
desh187
Copper - Posts: 310
Posted: May 13, 2005 at 8:46 PM / IP Logged
Then go ahead and install it to the wire i have mentioned above
