rsx 2002 wire diagram
Welcome Guest :)
strike92901
Member -
Posted: November 17, 2002 at 9:58 PM / IP Logged
im installing an auto start on my car and need to track down
some wires
tanks
diabloed
Copper -
Posted: November 17, 2002 at 10:26 PM / IP Logged
| <>12volts | white | + | ignition harness |
| <>Starter | BLACK/ white | + | ignition harness |
| <>Second Starter | none | | |
| <>Ignition | BLACK / YELLOW | + | ignition harness |
| <>Second Ignition | BLACK/ red | + | ignition harness |
| <>Third Ignition | none | | |
| <>Accessory | WHITE/ red | + | ignition harness |
| <>Second Accessory | none | | |
| Keysense | | | |
| <>Power Lock | WHITE/ blue | - | either kick panel or |
| Notes: Also found at the multiplex control unit on the back of the fuse box in a 13 pin plug. |
| <>Power Unlock | WHITE/ green | - | either kick panel or |
| <>Lock Motor | yellow/black | | driver kick panel |
| <>Unlock Motor | YELLOW /GREEN | | driver kick panel |
| <>Parking Lights+ | RED / black | | fuse box |
| <>Parking Lights- | blue | | headlight switch |
| Hazards | | | |
| Turn Signal(L) | | | |
| Turn Signal(R) | | | |
| Reverse Light | | | |
| <>Door Trigger | | - | security control unit |
| Notes: The driver door trigger is green and the passenger door trigger is lt. GREEN/ red. Use both wires and diode isolate each. The security control unit is to the left of the steering column.The driver door trigger is green and the passenger door trigger is lt. GREEN/ red. Use both wires and diode isolate each. The security control unit is to the left of the steering column. |
| <>Dome Supervision | comes on with unlock | | |
| <>Trunk/Hatch Pin | red | - | security control unit |
| Notes: The driver door trigger is green and the passenger door trigger is lt. GREEN/ red. Use both wires and diode isolate each. The security control unit is to the left of the steering column. |
| <>Hood Pin | GREEN/ black | - | security control unit |
| <>Trunk/Hatch Release | none | | |
| Power Sliding Door | | | |
| <>Factory Alarm Arm | WHITE/ red | - | security control unit |
| <>Factory Alarm Disarm | white | - | security control unit |
| Notes: The driver door trigger is green and the passenger door trigger is lt. GREEN/ red. Use both wires and diode isolate each. The security control unit is to the left of the steering column.May need to use relay in certain applications. |
| <>Disarm No Unlock | none | | |
| <>Tachometer | blue | | tach test connector |
| Notes: The tach test connector is behind the driver side headlight. |
| Wait to start | | | |
| <>Brake Wire | WHITE/ black | + | brake pedal switch |
| Parking Brake | | | |
| <>Horn Trigger | orange | - | steering column |
| Notes: The horn trigger at the security control unit is green. |
| Memory Seat 1 | | | |
| Memory Seat 2 | | | |
| Memory Seat 3 | | | | |
| Immobilizer By Pass : This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. |
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. |
Tuesday, May 12, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
