05 Kia sportage wire colors?
Ren92
Copper - Posts: 56
Posted: May 16, 2005 at 10:41 AM / IP Logged
Does anybody have the wire colors for a 05' Kia sportage?
chungo
Copper - Posts: 135
Posted: May 16, 2005 at 1:00 PM / IP Logged
12voltswhite (30A), red (30A) + ignition harness
Startergreen + ignition harness
Second StarterN/A
Ignitionblue + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessoryorange + ignition harness
Second Accessorypink + ignition harness
KeysenseWHITE/ orange + ign harn or ETACM, 22P plug, pin 10
Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the radio and heater control opening.
Power Lockgreen - DKP or ETACM, 26 pin plug, pin 19
Power Unlockblue - DKP or ETACM, 26 pin plug, pin 21
To unlock the driver door only, use gray/orange (-) at the ETACM, 26 pin plug, pin 25.
Lock Motorred 5widriver kick, door harness
Unlock Motorgreen 5widriver kick, door harness
Parking Lights+green (L), green (R) + back of fuse box, 18 pin plug
Parking Lights-brown - sw. or ETACM, 22 pin plug, pin 8
HazardsORANGE / black - ETACM, 26 pin plug, pin 10
Turn Signal(L)blue + turn signal switch
Turn Signal(R)green + turn signal switch
Reverse Lightwhite + back of fuse box, 18 pin plug
Door Triggerorange - DKP or ETACM, 22 pin plug, pin 13
Dome Supervisionbrown - ETACM, 26 pin pug, pin 1
Trunk/Hatch Pinblue - DKP or ETACM, 22 pin plug, pin 14
Hood Pinwhite - sw. or ETACM, 22 pin plug, pin 15
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometerblue ac cluster, 20 pin plug, pin 19 or ECM
Notes: The ECM (Engine Control Module) is on the driver side firewall, under the hood.
On the 2.0L, the tach wire is in pin 66.
On the 2.7L, the tach wire is in the 40 pin plug, pin 17.
Can also go to any fuel injector and use the wire that is NOT white.
Wait to startN/A
Brake Wirered + brake pedal switch
Parking Brakeblue/orange - sw. or ETACM, 22 pin plug, pin 17
Horn Triggerblue - horn switch
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
Interface Module:Category:
Required:
Yes
Type:
Transponder
Part #: 556U or 555U
Notes: N/A
05 Kia sportage wire colors? -- posted image.
