One Touch Power window diagram
gonethavorn
Member - Posts: 6
Posted: May 20, 2005 at 11:25 AM / IP Logged
Help me out anybody!....Please let me know how to wire my window switch that controls my passenger side to be one touch down operation like my drivers window....Thanks.
Powermyster
Silver - Posts: 962
Posted: May 20, 2005 at 11:48 AM / IP Logged
the likes of cliffors smart windows and some other window modules can make all your windows one touch   as standard its part of the switch its self. atleast thats what i always thought
mito57
Member - Posts: 46
Posted: May 20, 2005 at 12:14 PM / IP Logged
I don't agree with that. You can install the module without an alarm.If you want you can use a pushbutton to give the module the ground pulse and activate it to roll the windows or just don't conect the activation wire and still use the one touch feature.
wirewise
Moderator - Posts: 489
bobk wrote:
All window modules require a after market alarm install first, If none then factory switch is drivers window only.
Since when do "all" window modules require a after market alarm install first?
You can use almost anything to trigger a window module. Some will have different features, but not all require an alarm install first.
~wirewise~
Pearl96Max
Member - Posts: 16
Posted: May 20, 2005 at 2:01 PM / IP Logged
Just wiring in a 530T would do the trick. The windows would still function one-touch up/down. Just no connection for ground when armed or activation.
