compustar 2WAMR, 1990 mazda rx7
mattyfatsax
Member - Posts: 10
Posted: May 26, 2005 at 2:40 AM / IP Logged
I got a lot of extra time on my hands now because my license just got taken away for something that I'm not even guilty of. Anyways, I have 6 months until I can drive my car again so I plan on learning something. I just bought a compustar 2WAMR alarm system. In the box it came with Compustar AS controller (CM3000), one 2 way remote, one one way remote,antenna, shock sensor, siren, and lots of wires :D. Im am not too advanced when it comes to electronics so as I said, im hoping to learn something with the help of some patient individuals. I was planning on getting this installed at a shop but considering my conditions I would rather keep myself busy by working on my car. I am also not expecting to install this in a day or 2, I dont mind if it takes me 3 months as long as I do it. My first question:
I would like to have the following features installed:
-working remote start
-basic alarm install
-immobalizer of some sort
-starter kill
-power door locking/unlocking
-hood and hatch pin
-LED light flashing when alarm is activated (mounted on back of rear view mirror)
Question: If all I have are the things listed in the first paragraph (stuff that came with the alarm), which other things will I need to accomplish my goals.
Some background information about my car:
-1990 mazda rx7 turbo II
-power doors, power windows
-2 door hatch back style
-standard transmission
thank you for any help, please be gentle, im the biggest newbie you'll ever meet when it comes to electronics.
KarTuneMan
Platinum - Posts: 7,056
Posted: May 26, 2005 at 11:02 AM / IP Logged
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=467&product=Remote%20Start
Start by looking at a tech sheet, to help you locate wires and such
mattyfatsax
Member - Posts: 10
Posted: May 26, 2005 at 4:06 PM / IP Logged
ya that looks a lot more user-friendly than what they gave me in the instruction booklet. But don't I need certain things? Like hood pins/trunk pins... maybe a few other things to make all those features work? I noticed that the kit came with a small LED but what I want is a long one, i dont know how to describe it. Would I just buy the long LED and plug it into where the small one goes instead of the small one?
thanks
matt
Platinum - Posts: 12,488
Posted: May 26, 2005 at 7:37 PM / IP Logged
-starter kill
-hood and hatch pin
  • The remote start you will need to bypass the clutch switch with a relay.
  • The basic alarm system you just have to tie into the door triggers, trunk trigger and add the supplied hood pin switch. The impact sensor will take care of the impact portion of the security
  • Immobilizer . you can use the starter disable & if you want more, you can hook up other devices, but try to steer clear of an ignition disable.
  • Power door locks you will need to add an actuator for the central door locking system that you have on the Mazda. The use of 2 relays is necessary to make this work.
  • The LED that your speaking of is a scanner and all you need to do is wire in a relay to activate it when the system is armed.
mattyfatsax
Member - Posts: 10
Posted: May 27, 2005 at 1:42 AM / IP Logged
wow thank you that cleared it up a bit. One quick thing though... I was having difficulties starting my car a while back because the clutch safety switch was messed up. So me and a friend just simply dissabled the switch so that I can start the car without having the clutch pressed in. Do I still need to bypass the clutch switch with a relay or is this fine?
mattyfatsax
Member - Posts: 10
Posted: May 27, 2005 at 1:46 AM / IP Logged
sorry but what exactly is the actuator used for?
mattyfatsax
Member - Posts: 10
Posted: May 27, 2005 at 1:55 AM / IP Logged
I'd like to rephrase my last question. I was under the impression that if you have power door locks/windows that you dont need actuators? Could you possibly explain why I do? Also, where do i pick up a scanner? Where can I buy the hood/hatch switches?
thanks
Posted: May 27, 2005 at 9:14 AM / IP Logged
If it's been permanently bypassed then you don't need a clutch bypass, but I HIGHLY RECOMMEND that you leave the internal loop uncut for manual transmission vehicles so that you still have to place the system into ready mode for remote start.
You need an actuator because the Mazda uses a system where the driver's door lock controls the passenger side as well known as a central locking system. This system does not have an actual switch that controls the door locks so there is no control wire for each individual door lock motor, that is why you need an actuator to control the door locks.
The scanner's you can buy at any car audio/security shop or online somewhere and the hood pin switch you should have received one from the COmpustar package. It is part of the system when you buy a Compustar system ( unless the place you bought it from is hocking the pin switches compustar 2WAMR, 1990 mazda rx7 -- posted image. )
mattyfatsax
Member - Posts: 10
Posted: May 28, 2005 at 3:51 AM / IP Logged
ok that makes sense. Haha well to my knowledge it didnt come with any hood pin switches or anything. All of the places I've been asking for quotes have been saying that its $25 per pin switch. I'll see if I can buy one from instalation places but I hope they aren't $25 a piece :P.
thanks, if I come up with anymore questions I'll be sure to ask
I apreciate your help,
Matt
hawn13
Copper - Posts: 171
Posted: May 28, 2005 at 8:33 AM / IP Logged
if they are going to charge you 25 don't get it. it should be around 5-15 for a pin switch. if its going to be that much it should be a mercury switch. which in my opinion are better. you shouldn't need one for you truck if your dome light comes on when you open it. you could check online for pin switches. crutchfield maybe
