Clifford Wire Pin Number
rhinopower
Member - Posts: 32
Posted: June 02, 2005 at 3:53 PM / IP Logged
On a 12 pin harness with the heavy AGU wires, should the number on the pin be the same as the number the wire connects to inside the brain itself as the wires are all labeled there??
The alarm in question is a solaris.
rhinopower
Member - Posts: 32
Posted: June 03, 2005 at 1:55 AM / IP Logged
then i've not got a fooking clue!
currently with brain connected ignition is staying on permenant, as are indicator (parking lights) and the dome light, what could be causing it?? the brain was reprogrammed fresh couple of days ago?>
Powermyster
Silver - Posts: 962
Posted: June 03, 2005 at 6:01 AM / IP Logged
More info.
When did this happen when was the alarm installed. did you install it.
Post exactly what the problem is. Its easier on everone in the long run
rhinopower
Member - Posts: 32
Posted: June 03, 2005 at 6:39 AM / IP Logged
This happened when alarm installed.
Inside the pin numbers dont correlate to the pins on the plug.
Regardless of key position ignition stays on
Parking Lights permenantly on
Dome light permenantly on
All looms are wired correctly and tested
Could it be a bad earth?
meltingplastic
Copper - Posts: 225
Posted: June 04, 2005 at 10:31 PM / IP Logged
make sure the negative trigger for the relay isnt being shorted out somewhere and causing the relay to flip.. so that on a malibu where an installer didnt tape the ribbon cable for the ignition wires and the accesory wire was on all the time...
Driving a Bagged, Caddied 02 s10
