Nitro alarm
nyto
Posted: June 24, 2005 at 2:38 PM / IP Logged
hey i have a question...........the nitro alarm 2 way has 6 wires for locking and i have a problem conecting  do i need a realeys how they work i have a 91 ford explorer if i need a realey wish cables do i connect to the realey please help me thanks
nyto
Posted: June 24, 2005 at 3:56 PM / IP Logged
Nitro alarm -- posted image.
mo12v
Posted: June 24, 2005 at 5:27 PM / IP Logged
Depending on your vehicle...........You may need to hook it up 5 wire Reversal or Negative Pulse
Either way your Alarm is able to accommodate either one
Power LockPINK / YELLOWDRIVER KICK
Power UnlockPINK/LIGHT GREENPANEL **
** With OEM Keyless Entry ...... Negative Pulse Door Locks
 Without OEM Keyless Entry ....Reversal Rest At Ground Power Door Locks
It Is Common For Lock & Unlock Wire Colors To Reverse.
MO
