01 Dodge Ram Door lock ?’s
hy_tek69
Posted: July 05, 2005 at 11:47 PM / IP Logged
Installing Remote Start (Infinity 1005) on a 2001 Dodge Ram 1500.  No factory alarm or RKE.  Remote start and alarm work fine.  Can't seem to get door locks to work.  Used this setup:
01 Dodge Ram Door lock ?’s -- posted image.
Locks trigger once, but relays don't disengage and motor stays either locked or unlocked can't move even manually. Only way to disengage motor, is to pull pwr from coil.  Am I missing something simple?
Teamrf
Gold - Posts: 1,031
Posted: July 06, 2005 at 12:03 AM / IP Logged
only the unlock wire requires a relay. The lock wire is a positive trigger.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Moderator - Posts: 12,488
Posted: July 06, 2005 at 8:29 AM / IP Logged
If the relay is staying engaged, then make sure that the (-) trigger that your using is only a pulse not continous.
