viper791xv problem
Integrity
Copper - Posts: 66
Posted: July 16, 2005 at 4:39 PM / IP Logged
Just when i thought my alarm problem was fixed it came back like a bad rash. I have a viper 791xv that was just reinstalled and the tech mentioned that the former installer who got fired forgot to install some wiring needed for my alarm.
with that in mind this guy appeared to seem what he was doing so my alarm was reinstalled it worked fine for 3days and now its doing its thing again. when i go to remote start the car nothing happens the gages turn like its trying to crank the car but nothing happens. and now sometimes my parking brake lights remain on so if i unplug the alarm the lights go off. Dei has replaced this alarm but yet i am still facing this problem I even got pulled over because the alarm seemed to cause the parking brake lights to come on and off on there own while driving. before the install i had the same problem and i would wiggle the stinger shock sensor and the car would start i tried that this time and nothing any ideas before i rip this piece of shhh alarm out? never had so many problems with such a device thats supposed to be top quality.
auex
Platinum - Posts: 5,041
Posted: July 16, 2005 at 5:48 PM / IP Logged
Don't go blaming the alarm just yet. What kind of car do you have? Auto or manual? The brake light is almost undoubtedly install related and the no crank is more then likely something wrong with the immobilizer defeat or faulty installation.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Integrity
Copper - Posts: 66
Posted: July 16, 2005 at 9:19 PM / IP Logged
I have a 2004 ford explorer but the thing is now been installed twice and same shhh happens i get no where with callind dei cause they just want to pocket money and provide no support they tell me to go see the dealer or pay another dealer to install it how much money do i have to shell out before this gets fixed
Integrity
Copper - Posts: 66
Posted: July 16, 2005 at 9:35 PM / IP Logged
oh yeah its automatic i was not aware of a ford explorer being manual if there is such a thing
neilfrombestbuy
Member - Posts: 19
Posted: July 17, 2005 at 2:00 PM / IP Logged
yep, your remote start problem does sound like a problem with the immbolizer problem. have the place that installed it check to make sure the immbolizer around your key ring is secure and working. as for your parking brake lights, is it your parking lights that are on or is it your brake lights, if it is your parking lights that are on after you try to remote start it, sounds like the installer tried to use what they called a timed output to remote start your car instead of using a tach signal. either way is fine, just that if they used tach, the alarm would reconize your car not starting and would shut off (including your lights).
most likely installer error than product, dei makes great alarms
Integrity
Copper - Posts: 66
Posted: July 17, 2005 at 2:39 PM / IP Logged
ok is this imobilizer the 555u unit that the key is placed inside you know the little black box because other then that i do not recall them using a wire that loops around the ignition key entry. and i made a mistake is not the parking brake is the actual brake lights that remain on as i am driving  thats how i got pulled over and even after i shut off the car they remain on at times and when i disconnect the alarm the go off.... i am pissed that i been dealing with this problem for so long if there is anyone that can correct this problem in the central jersey area let me know i will pay you. but not the prices the other dealers been asking me for 250 dollars to reinstall the alarm the hell with them i rather ebay it.. guys let me know how can i correct this problem and my other post was how can i program the spare remote from the older viper 690xv or whatever it was is the white remote. look for my other post and you will see the picture of the remote
https://www.the12volt.com/installbay/forum_posts.asp?tid=59153&KW=791xv
Integrity
Copper - Posts: 66
Posted: July 18, 2005 at 3:36 PM / IP Logged
any help would be appreciated i am not sure what do you mean on the immobilizer i have a box that an extra key goes in thats labeled 555u is this the imobolizer you are referring to? or are we talking about something else
Integrity
Copper - Posts: 66
Posted: July 19, 2005 at 9:33 PM / IP Logged
over 130 people have read this request for help but only two people have helped please if anyone can help me out it will be appreciated the dam lights did it again this evening its making me crazy
diabloscope
Member - Posts: 48
Posted: July 20, 2005 at 3:00 AM / IP Logged
Take it back ! !   get a refund , they sound like a bunch of   d.m.f 's  then take you car and you money  somplace else ,  they have been helping you and told you what sounds like it could be the problem , if you dont know how to install or knowledge about them dont try to fix yourself you could be in for some more problems in the longrun ,    Just My Opinion ! ! !     Good Luck ! !
wiretapper
Copper - Posts: 166
Posted: July 22, 2005 at 1:44 AM / IP Logged
That's because most of this thread consists of babble and complaining instead of giving detailed info in order to diagnose the problem correctly.
