99 silverado keyless entry relay
slimthug30641
Member - Posts: 12
Posted: July 26, 2005 at 8:53 PM / IP Logged
I just got a bulldog keyless entry M/N-Ke100 now my truck all ready had actuators but no keyless entry or alarm, so   i ran wires to my keyless entry i got 3 relays 2 for the locks and 1 for my headlights to flash when i hit the unlock/lock button and it works perfect so then i tried hooking up the lock relays i tried 3 wire positive/negitive and actuator / Reverse Polarity and none of them work i know the relays work cause i hooked them up to the headlight flash and it works.the actuators only have 2 wires if u get a 9volt battery it will lock/unlock when u switch the wires to + & -.So my question is should i get a new alarm with a keyless entry or new actuators.unless anybody else can figure out what the problem is.Thanks ryan
iskidoo
Silver - Posts: 1,048
Posted: July 27, 2005 at 1:15 AM / IP Logged
No, you should be able to use what you have to make everything work.
Wire your relays like the top part of the diagram.
http://64.85.6.129/extrainfo/diagrams/14301_STORM_ACTUATOR%20DIAGRAM%20JBS%20UNITS.pdf
Or use this diagram from this site in the relay section.
99 silverado keyless entry relay -- posted image.
https://www.the12volt.com/doorlocks/page3.asp#arp
Steve G
